Steering adjustment.
Old Sep 2, 2013 | 09:13 AM
traildog's Avatar
traildog
Default Steering adjustment.
Help me out. My steering is "loose as a goose" and I'm attempting to tighten it a bit.
The picture shows (and yes, i know there's dirt under there, and thanks for noticing) where the book says the adjusting nut is located.
All I see is a bolt holding the brake line on, and a c-clip.
Do I remove the nut and c-clip and then find the adjusting nut? I don't want the dam thing to fall apart when I remove the clip.
Old Sep 2, 2013 | 09:31 AM
Uncle G.'s Avatar
Uncle G.
The adjusting nut is at the other end of the steering stem, under the big chrome cap. You will need to raise the front end of the bike off the ground. Next, loosen the two pinch bolts on the lower tree (under the front fork cover (5/8 wrench). You may also need to loosen the hardware holding the light bar and fork covers to allow everything to "move" when you tighten the bearings. Unscrew the big chrome cap (try gripping it with a piece of rubber for traction). Underneath you will find a big nut, which is your adjuster. Next loosen the "pinch" screw on the upper tree (on the back of the upper tree, just below the adjuster nut).
Tighten the adjuster nut and check the adjustment per the manual. Retighten all the hardware and enjoy.
You won't do anything by removing the screw underneath in your photo, but that's not where the adjuster is, either.
Old Sep 2, 2013 | 09:41 AM
traildog's Avatar
traildog
That's what I thought all along, but, that's not what I see in the shop manual.
Do you see the gap at the bottom of the stem?
She's up on the lift now, and the steering won't even stay centered. It flip flops back and forth, but I can't feel any weird "play" in it like the bearings are bad.....
Old Sep 2, 2013 | 11:12 AM
traildog's Avatar
traildog
Thanks Uncle G got her adjusted, and as soon as the visitors leave, I'm going to find out if it helped the wobble.
Old Sep 2, 2013 | 12:48 PM
Uncle G.'s Avatar
Uncle G.
Glad to help.
Old Sep 2, 2013 | 04:29 PM
Spanners39's Avatar
Spanners39
You really ought to clean all the grease off the bearings....the thought of having gunk inside your bike will eat away at your brain....bearings won't last very long but at least they'll be clean...
Old Sep 2, 2013 | 04:32 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
How true!!!!
Hey TD don't forget to clean your wheel bearings as well!!!!!
Got to get all that nasty grease out of there!!!
Old Sep 2, 2013 | 05:05 PM
Spanners39's Avatar
Spanners39
Originally Posted by texashillcountry
How true!!!!
And there is heaps of nasty, thick oil in the tranny too!
Old Sep 2, 2013 | 05:30 PM
traildog's Avatar
traildog
Default Worked like a CHARM!
No wobble, bounce nothing....I bet I didn't turn that bolt 1/2-3/4 turns....
Too bad it cost me a new cap though. (don't ask)
And, Spandex and TLC..........Bite me..............
Old Sep 2, 2013 | 05:35 PM
Spanners39's Avatar
Spanners39
I'm asking.....
