Cable lengths for a 02 Superglide?
Old Dec 18, 2008 | 04:31 PM
CDNORTHCOTT0369's Avatar
CDNORTHCOTT0369
Stage II
Default Cable lengths for a 02 Superglide?
I have a 02 Superglide and wanna put 18" apes on it. Need some help getting the right length cables. Can anyone give me some recs?
Old Dec 18, 2008 | 05:23 PM
wkdavistx's Avatar
wkdavistx
Your throttle/idle cable housing length is 32.5" (not including the bends at the grip).
Your clutch cable is 64.69" long (31.74" from lever to adjuster & 32.95" from adjuster to tranny).
I don't know how long the brake line is, but it's easier to measure.
typically you'll measure the distance from the risers to the end of the grip on the stock bar and do the same on the new bar. Add the difference to the stock length and you'll be close.
Another method is to use string and tape to figure the needed length. Always take into account that clutch cables need as few bends as possible for ease of motion and throttle/idle cables are the same but not as severe.
Bottom line is there is no easy answer or formula for all bikes - each one is different and each bar is different (my 18" Wild1 Psycho Chubbys are wider at the grip than most other 18" apes - they are 37" wide).
Good luck and let us know if you have any other questions...
By the way, welcome to the forum!
Old Dec 19, 2008 | 09:33 AM
08fxdf43202's Avatar
08fxdf43202
I disconnected my cables from the stock bars, left them attached else wheres then removed the stock bars and risers from the bike. Installed the new 1.25" diameter bars and risers. Reinstalled the switch housings, master cylinder and clutch perch.
I was then able to position each cable how and where I wanted. Each one was held in place where it ran "short". I then measured the distance it was short with a tape measure.
Kingwilliamxxvi
Jul 8, 2019 02:58 PM
butterballs
Apr 8, 2014 02:12 PM
G-Lock
Jun 4, 2013 07:04 PM
DynaJ
Jan 5, 2012 09:38 PM
suntadz
Jul 29, 2011 07:03 PM
