Timer cover
Old Dec 21, 2008 | 05:10 PM
rglay's Avatar
rglay
Question Timer cover
Hey guys,
I'm no mechanic, but I've added a lot of bling to my '08 Fat Bob. The pipe side is almost all chromed out except the part that the timer cover is attached to.
What is that part and is it easily replaced if there is no chrome cover for it? Thanks for you help!!
Old Dec 21, 2008 | 05:56 PM
db252's Avatar
db252
Well, the part that you are talking about is called a timing cover. There are various choices from HD and tons from after market manufacturers. You usually can find them in matching sets for your primary cover as well. Just so you know, there is nothing under it. You can take it off at will.
Old Dec 21, 2008 | 06:58 PM
red devil's Avatar
red devil
I think your talking about a cam cover? That is what the timer cover is attached too. Cost is about $150 new from HD.
Old Dec 21, 2008 | 08:18 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The cam chest cover can be a PIA to take off without removing the forward exhaust, but it can be done. Put the wheels on a couple of boards so the bike leans a little more, this will minimize the amount of oil draining out when the cover is pulled.
Old Dec 22, 2008 | 01:02 AM
db252's Avatar
db252
OOOHHHHHHHHHHH. The 'cam' cover is what you are talking about. Yeah, HD sells them chrome and just drain the oil before you do it.
Old Dec 22, 2008 | 05:20 AM
jmpancoast's Avatar
jmpancoast
Here are a couple currently listed on eBay:
http://cgi.ebay.com/ebaymotors/HARLE...Q5fAccessories
http://cgi.ebay.com/ebaymotors/NEW-C...Q5fAccessories
Old Dec 22, 2008 | 08:56 PM
rglay's Avatar
rglay
Thanks to all! I appreciate the feedback!!
Old Dec 22, 2008 | 09:45 PM
wkdavistx's Avatar
wkdavistx
You don't have to drain the oil before changing the cam cover. You will only lose a few ounces when taking it off.
Old Dec 22, 2008 | 09:49 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Don't forget a new gasket and torque in sequence so you don't warp the new cover. Be sure to mark the location of all the fasteners and clean the threads and use loctite on them when you reinstall.
Tee Bagger
Dec 27, 2011 05:48 PM
mjaw
May 29, 2009 03:56 PM
anubisss
Oct 21, 2006 10:37 PM
