Derby and Timer covers
Old Dec 23, 2008 | 06:00 PM
HeliRider's Avatar
HeliRider
Default Derby and Timer covers
Can I change the derby cover without draining the lubricant?
Also, any issues with removing the timer cover as well?
Want to replace both with the black fin covers.
Thanks
Old Dec 23, 2008 | 06:02 PM
wafu321's Avatar
wafu321
Yes you can remove both without any problems.
JRK5892's Avatar
JRK5892
there is no fluid behind the timing... if you put a 2x4 under the stand (basicly get it level) you can swap the primary as well
Old Dec 23, 2008 | 06:06 PM
FUQUA's Avatar
FUQUA
No prob. did it a about 3 weeks ago.
Old Dec 23, 2008 | 06:14 PM
paul s's Avatar
paul s
I did mine on the stand without a spill. It also uses a different gasket.
Old Dec 23, 2008 | 06:24 PM
Centerline's Avatar
Centerline
Thanks
Like they said; and you will need a gasket for the derby cover when you swap it out.
Here is a black finned timer cover.....
and a black finned derby cover .....
Old Dec 23, 2008 | 06:26 PM
chad peterson's Avatar
chad peterson
Ya make sure the dealer gives you the right gasket, the stock cover uses a different one form what I remember aswell!
Old Dec 23, 2008 | 06:32 PM
DYJ's Avatar
DYJ
simple simple and simple.... and the fins look great
Old Dec 23, 2008 | 06:38 PM
lee's Avatar
lee
dont forget use a good quality t27 torx socket and a good whack with the mallet to loosen up on the derby
Old Dec 23, 2008 | 06:45 PM
HeliRider's Avatar
HeliRider
Default Thanks Folks.
Just took delivery of my new 2009 Fat Bob Vivid Black.
Let the fun begin.
