reused mine as well. no problems.
I think HD recommends that you replace the screws which have a special integrated seal built in. If you're going to get leakage - it will probably be at one of the screws.
Mud,
I wouldnt have a problem with John using the same seal on the same tank, but I think he's looking at replacing the tank when he gets it painted.
I'm guessing it wont be a problem if you've reused yours after you beat the sides in on yours. If theres any distortion, it would have showed.
You've stressed your tank way beyond the factory stamping, so your opinion is probably the most valued
