Install Forwards
Old Dec 28, 2008 | 05:33 PM
rounder's Avatar
rounder
Originally Posted by dagored11
The part number for the cap is 34640-93 and the set screw is 3231B - no, the cover does not come with a set screw! I believe the cap is around $18, but don't hold me to that price.
don't forget the piece that secures the mid control in place that attaches to case bolt.
Old Dec 28, 2008 | 06:47 PM
WS6 Formula's Avatar
WS6 Formula
Here's some info below on installing the Harley Davidson forward controls.
Originally Posted by WS6 Formula
You don't have to remove the primary on the 2006 and up Dyna's
The 2006 and up kit instructions requires you to remove the primary to install a longer rear transmission shift lever and to remove the original shifter shaft that goes through the primary cover. Both can be done without removing the primary.
I installed the 2005 kit (P/N 49080-03A)with a longer 2006 custom polished stainless steel shift rod (P/N 33815-06)that comes with the stronger heim joints (they won't break like the original joints). You have to use a longer shift rod with the 2005 kit other wise the front shift lever will hit the primary when you up shift. The custom shift rods are a lot nicer then the cadmium plated shift rod in the kit and the original that came with the bike.
Removing the original shift shaft lever
Get a hacksaw blade and tape each end with duct tape, leaving about two inches exposed in the middle. Also put some duct tape on the primary and cylinder cooling fins. Tape a wrench on one end to get a better grip (on the end of the blade so as you pull on the wrench you will be on the cutting stroke of the blade). Slip the blade between the primary and engine from the bottom of the bike with the wrench end on the bottom. Position the shaft so you can cut about a quarter inch from the lever (not in the welded area). Use your other hand to guide the top of the blade as you cut. After cutting through, the shaft will slide right out, and the lever will just fall to the floor.
Cover for the original shift shaft lever hole
I used a chrome carriage bolt http://www.chromebolt.com/51618-x-134-chrome-carriage-bolt-p-845.html, and put a two inch piece of rubber hose on the threads then added some shrink sleeving on the hose to get a nice snug press fit into the empty shaft hole. If you have a black primary: Paint a unplated carriage bolt. Aluminum cover: Scotch brite a chrome carriage bolt.
Installing the new rear trans shift lever
https://www.hdforums.com/forum/dyna-glide-models/220845-did-the-oem-forward-controls-last-week.html
(Don't do it, leave in the original) Using the original rear transmission shift arm has two benefits, appearance and performance. The shift rod will sit at a more level position, and you will also have a shorter shift throw.
Forward control part numbers here:
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Shift linkage part numbers here:
http://www.harley-davidson.com/brows...bmLocale=en_US
Check prices here:
http://www.chicagoharley.com/shop/
https://www.zanottimotor.com/shopping/partLookUp.html
Larger image here:
http://img56.imageshack.us/img56/276...1020x63bz2.jpg
Larger image here:
http://img56.imageshack.us/img56/437...2008059kp3.jpg
Old Dec 28, 2008 | 07:32 PM
jackinthebox's Avatar
jackinthebox
Hey WS6 you seem to have some knowlege on the whole cutting the shaft. Believe me I want to do the install myself. So what I am getting is if you cut the shaft behind the primary the shift lever will fall and then you can just pull the shaft out through the outer primary cover? So then is the only reason to do it the hd way is to put the plug covers that come with the kit and that the shaft would be reusable for a future reinstall back to mids?
Old Dec 28, 2008 | 07:59 PM
Gary7's Avatar
Gary7
Right. Once you cut, the lever falls off. Then you pull the shaft out thru the outer primary. Then you use the plug for the hole just as if you'd followed Harley's (ridiculous) directions and pulled the primary in order to remove the shaft.
Old Dec 28, 2008 | 08:24 PM
jackinthebox
Ok guys got sometimes alittle slow with the easy way of doing things. Thanks for the advice.
Old Dec 28, 2008 | 09:04 PM
WS6 Formula
Yup! Did you read this part of my above instructions? "I installed the 2005 kit"
Yes. just like what "Gary7" wrote below
If you cut the shaft out then you can use the plug that comes in the 2006 and up kit, if your indecisive, leave the shaft in there until you put some riding time on the bike to make sure you like the forwards, then cut the shaft out.
Also keep in mind the instructions I posted are for installing the 2005 and earlier kit. Some have installed the 2006 and up kit and had problems finding neutral, I not sure but the 2006 and up kit may have a longer front shift lever and that would shorten the movement needed even more when using the original rear shift lever.
I think Harley's 2006 and up kit may have been designed to help the dealership service departments make money, especially if they figured out that they don't have to pull the primary to change the rear shift lever.
Old Dec 28, 2008 | 10:27 PM
Gary7's Avatar
Gary7
I was going to get the dealer to install mine before I took delivery, but I told them I didn't want the primary broken open. They refused to do it without following the directions. They took me back in the shop so their "lead technician" could explain to me that Harley wouldn't require the primary be removed "unless they had a good reason." When I asked what that reason was, he said safety. I said, no it's so you guys can bill 5 hours of labor for a job that need not take more than an hour. I looked the guy square in the eye and said "Doesn't it bother you to break open a brand new engine to install friggin forward controls? Isn't there something wrong with that picture?" He just shrugged.
Old Dec 29, 2008 | 08:35 AM
dagored11's Avatar
dagored11
Default Shift lever retaining bracket
The retaining bracket number is 34639-01 (01/later) and 34639-93 (93-00). You will also need a 5/16-18 x 5/8 hex screw with lock nut to attach the bracket to the shift shaft.
Old Dec 29, 2008 | 09:39 AM
michaelvs710's Avatar
michaelvs710
does anybody have a writeup on how to install 08 i went and bought black forwards for the SB
Old Dec 29, 2008 | 03:13 PM
OhioSkully's Avatar
OhioSkully
Thanks dagored and rounder those part numbers are correct i just came from the dealer stopped on way home from work the chrome cover is $19 bucks and the bracket to hold in place is $11 bucks. Didn't check bolt and nut price cause ill get that at local hardware cheaper. Iam just going to get this stuff had to order it and be done with it for now and if i ever need to open up the primary i will remove the shaft then.
Andrew17019
Jul 8, 2013 03:03 PM
brino
Mar 20, 2011 11:25 AM
acedantinne
Aug 8, 2008 11:00 AM
stbobber
Mar 30, 2007 10:11 PM
Skydiver
Feb 24, 2007 06:37 PM
