smart siren help
Old Dec 27, 2008 | 06:08 PM
togfish's Avatar
togfish
Question smart siren help
Does anyone know where they mount the optional siren for security system on an '09 FXDC? I've got the siren from the '07 Sporster I just traded in and would like to use it. Thanks for any help.
Old Dec 27, 2008 | 06:43 PM
08fxdf43202's Avatar
08fxdf43202
On my 08 Fat Bob it sliped into a place that was molded into the electrical caddy beside the ECM.
Remove the cover and the seat. Remove the two bolts on the top of the frame (under the seat) and the bolt in the center of the electrical caddy that hold it in place. Shift it out & down and locate the slot on the back side. Plug in the siren and swizzle it into place.
Old Dec 28, 2008 | 03:23 PM
togfish's Avatar
togfish
Thanks a lot, I'll give it a shot.
Old Dec 28, 2008 | 04:38 PM
ngoti8tor's Avatar
ngoti8tor
Remove the maxi-fuse before you start.
1. remove the electrical caddy screw and washer and tip the top of the electrical caady away from the bike
2. turn the siren so the sounder disc faces upward and the wire receptacle is facing the bike
3. remove the siren harness lead (taped to the bike frame behind the caddy) and remove the dust cap
4. plug the harness into the receptacle on the siren, then insert the siren into the back of the caddy, beneath the ignition control module
5. install the caddy screws and washers
6. feed the siren antenna wire under the rearmost frame crossmember and up between the crossmember and the rear fender
7. clean the top surface of the crossmember with alchohol and water, then allow to dry
8. attach one part of the velcro to the top of the frame crossmember
9. lay the siren antenna wire on top of the secured velcro and straighten the antenna along the length of velcro
10. make sure that NONE of the small diameter portion of the antenna touches any metal parts of the bike or it will not work properly
11. install the other half of the velcro on top, capturing the antenna wire to hold it in place
12. install the maxi-fuse
This should help you.
Old Dec 30, 2008 | 04:19 PM
togfish's Avatar
togfish
Thanks guys. Did it today and it works fine.
SunDevil45
Mar 4, 2021 12:37 PM
FLHGLIDE
Jun 15, 2013 08:36 PM
jay87LX
Mar 29, 2012 11:43 PM
MX Mark
Nov 6, 2011 12:40 PM
biz44
Jul 8, 2009 11:32 AM
