Risers on FXDC?
Old Jan 4, 2009 | 11:19 AM
Gary7's Avatar
Gary7
I just measured my bars. They are 1". I guess I was thinking they were 1.25" because the grips feel thicker than the ones on my Sportster.
Old Jan 4, 2009 | 11:44 AM
Gary7's Avatar
Gary7
Are the stock FXDC risers aluminum or steel? I'm seeing both in the aftermarket risers and I want to stick with whatever the bike came with.
Edit: Nevermind. I just put a magnet on 'em. They're aluminum.
Old Jan 4, 2009 | 02:03 PM
Gary7's Avatar
Gary7
For you guys that have put risers on yourselves, what is involved if you do have to pull some extra wires out of the frame for a little more length? Do you have to pull the tank off, or what?
I think I'm going to got with these. They are 2.5" rise with 1.5" pullback. Stock is 2" rise with no pullback.
Old Jan 4, 2009 | 02:09 PM
devils haircut's Avatar
devils haircut
Don't be scared of 4 little allen bolts. Just take the top clamp off and see how high the bars will go before the cables get tight...and that's how high you can go without having to change anything other that the riser it's self.
Old Jan 4, 2009 | 02:23 PM
Gary7's Avatar
Gary7
I'm going to have to pull some slack on the wires if I go up any at all. That's what I'm asking about. What's involved in pulling the extra slack? On my Sportster, you had to pull the tank and the extra slack was under there where the wire harness was looped and held with a tie-wrap. Cut that tie-wrap and take the loop out and you instantly had an extra 3" to play with, and I needed every bit of it when I put the buckhorn pullbacks on in place of the stock bars.
Old Jan 4, 2009 | 02:54 PM
ZeroFiveFour's Avatar
ZeroFiveFour
Mine are Chrome.
2007 fxdc
All I had to do was pull a bit of the slack out from the hole in the side of the frame that has the rubber gasket on it.
You could always disconnect the tank mount bolt up front near the trees, prop up the tank with a small block of wood, or bunched up kitchen towel. Then find the electric line, and fish a bit more through. A bit more trouble, but easy non the less.
Cheers and Good luck.
Tom
Old Jan 4, 2009 | 03:49 PM
Gary7's Avatar
Gary7
Originally Posted by ZeroFiveFour
Mine are Chrome.
Mine are, too: chrome plated aluminum rather than chrome plated steel.
Also, someone had posted in another thread where I asked about the spokes on the std wheels that they are stainless. Well, they aren't. Magnet sticks to 'em which means they're regular ol' chrome plated steel.
RANGER73
Nov 12, 2018 12:00 PM
cooperk851
Oct 30, 2012 01:21 AM
nc883
Aug 5, 2012 02:29 PM
mnelson37
May 7, 2010 03:59 PM
OKbrandman
Jan 27, 2009 12:05 PM
