Just Wondering...
Old Jan 5, 2009 | 04:36 PM
Fupl18's Avatar
Fupl18
Default Just Wondering...
OK. I just took the reflectors off the BOB and it left behind some sticky gunk on the rear. How do you all recommend to get the rest of the sticky gunk off??
2. The Silver/Grey strip across the batt box!! how do i get it off to paint it.
Lastly I have recently put a SE heavy Breather on my 09 Fat bob and went step by step with the directions. The Directions that were provided were for a carb i think and i have EFI. the question is if anyone else out there with a 09 Fat BoB or 08 that has put one on did you have a wire that was left over hanging from the bottom??? it was connected to the stock air box but instructions said nothing about doing anything with it once the breather was on.. so if you all had a wire too what did you do with it? thanks for your time
Old Jan 5, 2009 | 04:51 PM
Cornhusker's Avatar
Cornhusker
Forget about the wire hanging down. It's for export bikes. Tuck it away somewhere. I plugged mine in the back of my Ness a/c.
Old Jan 5, 2009 | 04:52 PM
compgeek789's Avatar
compgeek789
Sticky residue: Goof off. Some people have had success with using a hair dryer to soften it up and then simply rub off with fingers.
Battery box: Single phillips screw on the underside of the battery cover. Take the cover off by removing your seat, unscrewing the battery box cover screw, and finally pulling the cover off. Once off, you'll see inside the battery cover and you'll see how to take the silver band off.
Oh, and while you've got the goof off can out and the battery cover off, take the opportunity to remove that battery warning sticker!
Cheers,
J
Old Jan 5, 2009 | 05:05 PM
Fupl18's Avatar
Fupl18
Thanks a Ton goin to get that stuff off right now lol.. what kind of paint do you all recommend for that strip?? one other thing to while i am at it.. i was thinking about gettin the black rush slip ons. what kind of paint would i use to paint my current heat shield black>>> or is this possible???
Old Jan 5, 2009 | 05:36 PM
SC-Longhair's Avatar
SC-Longhair
I just rubbed it off with my fingers. A little time-consuming but effective.
Old Jan 5, 2009 | 05:59 PM
compgeek789
You can paint your heat shields. I'm not a painter, and don't want to dispense bad advice. I've heard people have had good results from hi-temp coatings like those that are used on barbecue grills. There's a saying that goes something like "painting is 90% prep work and 10% painting". Don't expect to simply paint over chrome and have it come out looking anything close to decent. You'll probably have to scuff 'em and clean 'em before you can paint. But again, hopefully someone here with real experience and knowledge can help guide you.
Search the forums for exhaust paint. Lots of folks have done it. JRK, Special Ed, and a few others come to mind.
H-D sells wrinkle black in a spray can. Might work well for your battery band. But again, do your research on the prep work and curing process before you paint.
Old Jan 5, 2009 | 07:11 PM
Dawg Rider's Avatar
Dawg Rider
That should be "Goo Gone". DO NOT use Goof Off. Some forum members have done damage to their finishes with it.
Old Jan 5, 2009 | 08:24 PM
rockon's Avatar
rockon
I did it with Goo Gone and a plastic spoon, polished up with a soft cloth.
Old Jan 5, 2009 | 09:01 PM
compgeek789
Holy crap, thanks for catching my mistake Dawg.
Old Jan 6, 2009 | 06:45 AM
Dawg Rider's Avatar
Dawg Rider
No problem...those two are easy to confuse.
Wranglin4Life
Dec 28, 2013 03:51 PM
maxxod
Jul 15, 2009 09:07 AM
bosken
Aug 15, 2008 09:17 PM
Z28EATR
Mar 28, 2008 05:43 PM
Chipstah
May 23, 2007 07:49 PM
