few new mods
Old Jan 7, 2009 | 07:31 PM
952dave's Avatar
952dave
Default few new mods
Well i had syrgery last week so I've been using my time off woring on my bike. I painted the fork sliders, and I wrapped my pipes.Next thing on my list is to paint the cam cover and the transmission covers
Old Jan 7, 2009 | 07:59 PM
RockyTopRider's Avatar
RockyTopRider
looks excellent. just had surgery today. been wanting to paint my fork sliders. could you
advise the process you did. thanks in advance jeff
Old Jan 7, 2009 | 08:00 PM
dpriest's Avatar
dpriest
looks good, did you think about putting the rear shields back on? that what i did. I think it cleans it up a bit. what kind of paint did you use on the lowers?
Old Jan 7, 2009 | 08:01 PM
Fupl18's Avatar
Fupl18
Looks very nice. Guess surgery went well :P
Old Jan 7, 2009 | 08:44 PM
luckyB's Avatar
luckyB
Very nice work... rattle can?
Old Jan 7, 2009 | 11:05 PM
chad peterson's Avatar
chad peterson
Right on, dig the black! Haven't seen much of it with that blue, keep it goin!
Old Jan 8, 2009 | 01:30 AM
rounder's Avatar
rounder
process is simple.. *remove wheel, brake, and fender. Sand lowers with 220 grit. Mask off. Paint with epoxy enamel(appliance paint). Durable near powdercoat finish is yours for less than $10.
My lowers came out awesome...
I used ace hardware epoxy enamel paint. I also gave the lowers a couple of days before reassembly to cure a bit (5 days). epoxy takes 24 hours to dry fully. Thick stuff that is real easy to apply.
Old Jan 8, 2009 | 08:20 AM
RockyTopRider
thanks for the info. i've been reluctant to paint the lowers. also have been just using krylon flat on my other parts not appliance paint. is this the same as high temp bbq/grill paint? did you or do you advise using any type of primer?
Old Jan 8, 2009 | 09:51 AM
07bobber's Avatar
07bobber
Id rather tear it apart and get them powdercoated. Been thinking about getting it done myself.....
Old Jan 8, 2009 | 12:08 PM
952dave's Avatar
952dave
I removed the forks from the bike sanded all of the clear off of the sliders then used self etching primer (very important), then primed them with a high build primer, wet sanded with 600, then 2 coats PPG gloss black base coat, then finnished it off with 2 coats of clear coat. I had to have my appendix removed. The surgery went well, the worst part about it, is that it was right before new years eve so I didnt get to do much celebrating
