Tuners
Old Jan 12, 2009 | 03:41 PM
rockon's Avatar
rockon
Originally Posted by jake40ma
And with a pc 111 or pc v it would be in open loop ?? which means exactly what? Please pardon my ignorance but I'm not much into this stuff!!
No O2 sensors in the equation, which means you're running off a canned map the entire time...you can make adjustments, but still just a map.
Old Jan 12, 2009 | 04:06 PM
SC-Longhair's Avatar
SC-Longhair
One question I've always wondered about fuelmoto is...are the maps they send you the same maps you can download just as easily from the powercommander.com website or do they do tuning there and have a large catalog of maps for various setups and that is what they send you?
I'm just running the canned map from the powercommander.com website and my bike is fine. I also have the SE stage 1 air cleaner and SEII slip-ons.
My suggestion...just buy the pcIII. Maps are on the cd that comes with it. If it not, just download the map that closely matches your setup.
Old Jan 12, 2009 | 04:41 PM
bberck's Avatar
bberck
My experience with maps from my quad was they were not the same in most cases. The power commander maps were typically a little richer than maps from Fuel Moto for the same set-up.
Old Jan 12, 2009 | 08:21 PM
YellowHawk's Avatar
YellowHawk
This is all great info. I appreciate it. I'm not looking for the cheapest option necessarily. Mainly, the easiest option for right now. I don't want to spend $700-$800 for a tuner. I think I'm stuck between maybe the SE Super Tuner and the PCIII. Sounds like the PCIII would be the simplest option for me right now. I could go with a dyno run later but the canned map should get me close and get a bit more power out of it right?
Old Jan 12, 2009 | 08:57 PM
bberck's Avatar
bberck
Much improved throttle response and noticeable power increase with my SE Breather and PC5 addition. Install on the PC5 took about 30 minutes and was a easy install.
Old Jan 12, 2009 | 09:18 PM
Pepsimayn's Avatar
Pepsimayn
TTS will run you less than 500 from Doc, give him a shout, I think its worth the extra money over the SERT. You can use the TTS Vtune program yourself without having to pay for labor, and you have his support for free.
Old Jan 12, 2009 | 09:26 PM
Pepsimayn's Avatar
Pepsimayn
Yeah so is the way of speed density as well. If you can get the bike running correctly, it will only run correctly at one temperature and at one elevation. That margin of error may not be of concern to most, but is to me and should be for anyone who wants the most (performance and economy) out of their machine.
Semper
Old Jan 12, 2009 | 09:38 PM
archergodwin's Avatar
archergodwin
Sorry Jake, I've been having issues with the forum giving me a damn database error all frigging evening....
The stock fuel injection system utilizes oxygen sensors in your exhaust stream to calculate any adjustments to the fuel/air mixture. These are 'narrow band' sensors, and just as the name states only can correct a small amount because of their narrow band. When you start your bike it runs for a small amount of time in open loop, so that the O2 sensors can come up to temperature... yes they also need to be hot to work in their narrow band.
The PCIII system has you unplug or remove your O2 sensors, and I believe they have you plug something else in. (those that have the system can correct me.. thanks!) So it runs "open loop" meaning that there is no feedback.
The Thundertune max w/auto tune uses wide band O2 sensors, meaning they can correct over a wider range. This is why all kinds of mods can be done with this system, and it will correct the fuel/air mixture over a wide range. It's also bloody expensive... unless you plan on doing a lot of mods over time.
So when thinking about "closed loop" and "open loop", closed loop means there is feedback given to the system about it's operation condition. Open loop means you're running like a carburated system, no feedback on the operating status (fuel/air mixture). You're basically running 'best guess'.
Now folks have been running like that for years, and doing just fine. Fuel injection brings better driveability (in most cases, not all) because of the closed loop feedback, which takes into consideration air temp, air mass being passed and the amount of unburned O2 in the exhaust, to make it's adjustments dynamically.
That's kind of a short description of it, hope that helps!
Old Jan 12, 2009 | 10:01 PM
bberck's Avatar
bberck
Someone correct me if wrong but arent there seperate sensors air temp, density, and etc. The bikes have only had O2 sensors for a few years and they compensated for these thing before they had them. The O2 sensors are more for air flow which dont do enough for major mods since they are not wideband.
I have ran FI quads for awhile and they do not have O2 sensors and also adjust for temp etc. Even with a PC lll installed they would still adjust for temp and altitude.
I know there are different types of FI so just curious.
Old Jan 12, 2009 | 10:14 PM
Pepsimayn's Avatar
Pepsimayn
I'm not intimately familiar with the EFI on these bikes (yet) but I'm assuming they have IAT (Intake air temperature) MAP (Manifold absolute pressure) and of course the O2 sensors. I'm assuming they utilize a MAF (mass airflow sensor) as well but am not sure?
The matter of the narrowband sensors having less detection range is trivial if the system is near its target AFR. The issue is when tables are not tuned to reflect mods that the system itself cannot add fuel trim to make up for the difference.
Yut
