Tuners
Old Jan 13, 2009 | 10:08 PM
  #41
Pepsimayn's Avatar
Pepsimayn
Yes, they work only in closed loop. Under WOT your MAF, VE, and PE tables take over, this also requires the use of a wideband sensor for proper tuning.
For the gentlemen looking for EFI info I believe there is a thread call "EFI 101" or something like it, with more information than you'd ever care to know!
Old Jan 13, 2009 | 10:39 PM
  #42
mud's Avatar
mud
With the Screaming Eagle Race Tuner
tuning is accomplished on the dyno
by someone who knows what to manipulate in the available parameters.
And there are hundreds of variables.
The way my map (not MAP) is built, the o2 sensors never come into play.
Everything that the ECM knows and does
was set up to do what we wanted
(135 ft lbs torque from 2200 rpm to 4500 rpm).
mud
Old Jan 13, 2009 | 11:14 PM
  #43
archergodwin's Avatar
archergodwin
mud
Nice bit of info there mud. Didn't know that the O2 sensors were at the bottom of the "sensor priority chain", and that the ECM can choose to not react on their input.
That makes systems like the PCIII(+) even more attractive.
Old Jan 13, 2009 | 11:47 PM
  #44
Pepsimayn's Avatar
Pepsimayn
Depending on their intended use I disagree with this. Closed loop operation (relying on O2 sensors to adjust fuel trim) is hands down the best system for a cruising machine.
Speed density and or complete open loop rely on the calculation of air density/temp and MAP to run correctly. To tune this way i.e. with a PCIII is a lot less exact and in the way of cagers' speed density tuning is very complex.
Better left on the track, IMO
Old Jan 30, 2009 | 07:45 AM
  #45
dispatchokirt's Avatar
dispatchokirt
So I assume that the PC V takes care of this problem, since you can keep the O2 sensors plugged in ??? I also would hate to spend 800.00 for the SE plus dyno when teh PCV would work!
I am so confused!
Old Jan 30, 2009 | 08:34 AM
  #46
robertj74's Avatar
robertj74
I am so confused!
you don't keep the 02 sensors with the PCV it uses 02 eliminators just like PC3.,unless you upgrade to the autotune modules and wide band sensors.
St Glide
Mar 11, 2015 12:06 PM
mwegryn
May 23, 2011 08:10 PM
Delmarksman
Jun 22, 2009 06:49 AM
dhc8guru
Jan 9, 2008 10:47 PM
sedbiker62
Exhaust System Topics
Mar 12, 2006 07:29 PM
