Flush Mount Kit
Old Jan 11, 2009 | 02:33 PM
tonyva's Avatar
tonyva
4th Gear
Smile Flush Mount Kit
Hi
I have purchased a flush mount kit for my 06 wide glide, it has instructions for installing but not that clear on removing the existing fuel gauge and fuel cap. Thought maybe someone got some tips on removing.
Thanks
Old Jan 11, 2009 | 03:14 PM
dpriest's Avatar
dpriest
fuel cap unscrews, fuel gauge just pulls out. you have to unclip the wires below the tank where they come through. Ther are plenty of threads on this forum with details on how to do this. good luck and post some pics.
Old Jan 11, 2009 | 03:18 PM
rewog's Avatar
rewog
Remove the front tank mt, with the front of the tank raised you can get to the fuel gauge connector whose wires come out of a hole directly below the gauge.(it may be cable tied to the frame) Taking this lose will give you enough slack to pull the gauge up(pull straight up, don't twist) enough to unplug the original. (The instructions say to remove the plug under the tank and remove wiring and all, but the manual says if you're just replacing the gauge, simply unplug the harness from the gauge. I'm doing the same but don't want to have to remove the connector from the original and put it back on the new wiring if in fact the wiring is the same.
Old Jan 11, 2009 | 05:23 PM
Evil Stepdad's Avatar
Evil Stepdad
+1 on removing the front tank mount and lifting up on the tank to reach/find the connector. I screwed around for about 30 minutes trying to find that thing, and then finally removed the tank mount, and had the connector undone in about 30 seconds. It's amazing how much time you can waste trying to save time by skipping a step!
Old Jan 12, 2009 | 02:23 PM
tonyva's Avatar
tonyva
4th Gear
Thanks for the tips, I will let you know how i got on
Cheers
Old Jan 12, 2009 | 05:43 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Check out my post (# 4) in the thread below. Also, search on some of my other LED posts for info on problems I, and others have had with our LED gauges...hope you have better luck, but I still love the look of mine.
https://www.hdforums.com/forum/dyna-...-accuracy.html
ChromeBlows
Mar 22, 2015 01:13 AM
jbersaglia
Oct 6, 2014 10:23 PM
THBear
Mar 22, 2008 12:51 PM
jtmurph00
Jan 29, 2008 12:28 PM
Tooz
Apr 26, 2007 03:14 PM
