Voltage regulator on light upgrades
Old Apr 14, 2006 | 11:01 PM
Stucarius's Avatar
Stucarius
Default Voltage regulator on light upgrades
Some one told me today that on HD's with security systems you need to place some kind of voltage regulator or modulator if you upgrade you lights to LED's other wise the computer will see the voltage change as a problem with the light or even completely different electrical system warnings.
Has anyone heard of this as I cannot remember hearing anyone say anything about doing this when they did LED upgrades.
Thanks
Old Apr 14, 2006 | 11:20 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Voltage regulator on light upgrades
Yes... You need to install a load equalizer... Most manufacturers of LED's have them as well...
Your T/S's are controlled by the TSM/TSSM.... A certain amount of voltage must be registered for the TSSM and the ECM to communicate....
Check this Link out .... http://www.radiantz.com/c182.html
Old Apr 14, 2006 | 11:28 PM
DyNaBoB's Avatar
DyNaBoB
i have the led taillight and have no problems oops i dont have the security system thou
Old Apr 15, 2006 | 12:18 AM
Stucarius's Avatar
Stucarius
ORIGINAL: Shovelhead Bob
Thanks man,
Can you tell me if it must be installed once or must one be installed between each light or can it be installed once and all lights routed past it?
Old Apr 15, 2006 | 12:21 AM
Shovelhead Bob
It plugs in between the harness and the lights.... Install the Load equalizer as per manufacturers instructions, then install your lights.....
Old Apr 15, 2006 | 12:38 AM
Sooee's Avatar
Sooee
If it is just the tail/brake light, check out the manufacturer's instructions - most specify whether or not it is designed for the TSSM.
If it is the turn signals, yes, as Bob said, you need a load equalizer.
If it is the headlights - ???????
abbysdad2006
Electrical/Lighting/Alarm
14
Aug 29, 2021 07:23 PM
DieselDummy
May 26, 2015 05:02 AM
marvincbr
Mar 31, 2015 05:44 PM
lost_in_calgary
Nov 12, 2013 08:50 PM
hyfly1
Jun 30, 2009 03:56 PM
