Wiring question???
Old Jan 23, 2009 | 07:03 PM
Naz_Man's Avatar
Naz_Man
Default Wiring question???
This is the deal.... When I got my detach sissy bar it came with rear signal relocate kit.... the stem that holds the signal has a very small hole in which you are to run the wires through and after you mount them the wires have to make a 90 on the inside of the fender and back to the brake/tail light which is where they plug in. the problem is where they make that 90 they get wore out after a while the shielding get wore off and they ground out and quit working or make crazy things happen to the light system. my question is could I drill a small hole in the signal housing and put a small bolt through it and run the ground to it then tighten a nut down on it then just run the hot wire through the stem which would make a much nicer 90 and there would be some room for movement? Then in the tail light wire the 2 grounds from the clips together? ( See pic below )
What do you think? Would this cause a problem?
Thanks a lot, Donnie
Old Jan 23, 2009 | 07:06 PM
Lorance66's Avatar
Lorance66
I have to admit I don't understand your problem as I have never had mine apart but just thought I'd mention heat shrink tubing makes great anti-chafing material, and you can layer it as many times over as you like.......and I could be way off base from what you are asking......
Old Jan 23, 2009 | 07:25 PM
Naz_Man's Avatar
Naz_Man
The problem is the stem that the wires have to run through is to small for both wires.... so I wanna ground them inside the signal housing and just run 1 wire through the stem....And inside the tail light I want to wire the 2 grounds together!! Really hard to explain!!!!
Shrink rap lol.... there's not enough room for the wires more less some added shrink rap.
Thanks tho for your input, Donnie
Old Jan 23, 2009 | 07:39 PM
Lorance66's Avatar
Lorance66
ah, I see.......hmm.....is the bolt fat enough to drill it out a bit?
Old Jan 23, 2009 | 07:41 PM
Naz_Man's Avatar
Naz_Man
The stem is threaded on both ends no way to drill it out.... The hole looks to be as big as it can be!
Donnie
Old Jan 23, 2009 | 08:25 PM
Naz_Man's Avatar
Naz_Man
Maybe this will help, I drew the stems in so you can get an idea whats up!
Old Jan 23, 2009 | 11:05 PM
Lorance66's Avatar
Lorance66
ok, after seeing that and reading your first post over again I think I understand. I also think you are on to the right idea with the ground. If you have an ohm meter or a DVOM just set it to ohms (little omega symbol) and put one lead on a known good ground and the other on your intended new ground and see if you have continuity. If you do then you are set. Running one wire through there would be the easiest answer in my opinion and should not cause any problem whatsoever so long as the ground is good.
Old Jan 23, 2009 | 11:08 PM
Baeseman1's Avatar
Baeseman1
I'm not an expert, but I don't know why it wouldn't work. Look at most aftermarket headlights - no ground wire at all. It's grounded through the mounting bolt. You are basically doing the same thing. My directional turn signal bar only had 2 wires on it - left and right. So that ground wife from the harness is capped off and out of sight, out of mind...
Old Jan 24, 2009 | 05:57 AM
04fxdwgi's Avatar
04fxdwgi
Grounding can be tricky....... Take it from an automotive / marine electrician. You can surely ground anything to metal, but you need to ensure that whatever you ground to has a good ground path to the battery. What I mean is that if you ground to the stems, then make sure you use a good star washer to ground that stem to the what the stem is mounted to. Then you need to ensure that part is grounded, so on and so on. Best idea is to run a ground wire from the closest part that is convenient to the load (the light in this case) to the battery ground point. Then, when the light is on, take a volt meter, not ohm meter, and see is you have any voltage from the ground point of the load (light) and the battery negetive. This will measure any "voltage drop", indicating a bad ground circuit. If you have ANY voltage on the meter, you can then start moving the positive meter probe, leaving the battery negetive one in place, to each ground point, getting closer to the load. When the voltage drops to "0" you have gone PAST the bad spot, indicating where you need to focus attention on getting a good ground.
Hope this helps and didn't confuse you. If further explanation is needed, drop me a PM.
Old Jan 24, 2009 | 08:37 AM
Naz_Man's Avatar
Naz_Man
Thanks, I tried grounding it to the stem and it works I just wanted to make sure I wasn't gonna cause a problem doing it that way!
Thanks for the input guys, Donnie
Nlstreetbobber
Sep 2, 2021 01:55 PM
squaco
Electrical/Lighting/Alarm
Aug 26, 2014 10:10 PM
ncbeast
May 16, 2009 08:17 PM
ncbeast
May 15, 2009 06:25 AM
jackietan
General Topics/Tech Tips
Sep 8, 2007 06:48 PM
