Problem With Bike that Dealer Cant Fix !!!!
Old Jan 24, 2009 | 09:30 AM
archergodwin's Avatar
archergodwin
Good deal there Bobber. Sounds like a dealer change is in order.
By the way, you really don't want to jet wash these bikes. It is true that they don't like it. None of the connectors are sealed really well. Just a nice easy wash and rinse with a hose or bucket. If you do need to jet wash, you gotta be very careful where the stream goes. Limit it to the wheels/rotors and bottom of the motor/tranny. Hand wash everything else.
There are stories of guys drying out connectors with their wife's hair dryer and compressed air.
Old Jan 24, 2009 | 11:22 AM
Bobber Jay's Avatar
Bobber Jay
Ok Guys , home now and found out the codes my bike is displaying.
PO108
PO374
PO505
PO563
PO1475
PO1477
60563
61005
61007
Anybody help ?
Thanks
Jase
Old Jan 24, 2009 | 11:33 AM
mud's Avatar
mud
PO108
PO374
PO505
PO563
PO1475
PO1477
60563
61005
61007
Anybody help ?
Thanks
Jase
https://www.hdforums.com/forum/3788513-post5.html
P0108 Map Sensor Failed High Carb
P0374 CKP Sensor Not Detected Carb
P0505 Loss of Idle Sped Control EFI
P0563 Battery Voltage High EFI
60563
61005
61007
You sure that's a 6 and not a B??
B0563 Battery Voltage High TSM/TSSM
B1005 Fuel Level Sending Unit High/Open Instruments
B1007 Ignition Line Overvoltage Instruments
PO1475 don't know about this one
PO1477 don't know about this one
Old Jan 24, 2009 | 11:39 AM
PaleRearEnd's Avatar
PaleRearEnd
sounds like it needs an ecm.... 12 codes = wacked computer
B=Body or Battery?
PO=Engine
Old Jan 24, 2009 | 12:27 PM
TOMMAY's Avatar
TOMMAY
Sounds like the ecm connector is corroded from moisture. Pull the connector apart and clean the pins and coat liberally with di-electric grease. Just my guess.
Good Luck
Tom
Old Jan 26, 2009 | 01:19 PM
Bobber Jay's Avatar
Bobber Jay
Update guys,
Broke down on the way to the new dealer , bloody nightmare it was !!!
Had to call hog assistance who took me and the bike to the new dealers place.
Seem a really nice bunch of guys , dropped it straight onto the Diagnostics and he has mentioned it was showing "Crank Shaft Sensor" inop.
They have kept the bike in and will update me tomorrow as it was getting late.
So far so good as it should be covered under warranty.
Will keep you guys posted.
Anyone know or heard about the crank shaft sensor before , likely causes of failure ??????
Cheers
Jase
Old Jan 26, 2009 | 01:38 PM
notfried's Avatar
notfried
if it has thrown that many codes i agree with BA that the made in Mexico ecu is junk...like 1/3 of DelfiXican crap...ya may wanna suggest that to the dealer
Old Jan 26, 2009 | 02:47 PM
07bobber's Avatar
07bobber
That sux hope you get this crap sorted out.......
Old Jan 26, 2009 | 03:01 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
My guess is bad ECM or caddy.
Old Jan 26, 2009 | 04:14 PM
PaleRearEnd
Update guys,
Cheers
Jase
Crankshaft sensor produces ac voltage, it's basically a button magnet with 2 wires. Everything computer related on your bike runs off the crankshaft sensor. The sensor tells the ecm how fast the crank is turning which then, the ecm reads the map sensor to determine engine load, with those 2 (engine rpm and load) it then tells the injectors how much fuel to spray in junction with the throttle position sensor (how much the butterfly is open on your throttle body = air going into the engine).
it's all GM Delphi garbage, but it's better than EFI V 1.0 (pre delphi)
another reason why i'm having a hard time giving the dealer 22K for an 09 Roadglide... it's an air cooled cavalier on 2 wheels
Bogie_71
Mar 13, 2016 08:27 AM
the4thgearkid
Oct 4, 2014 07:39 PM
08bluepearl
Aug 6, 2009 12:20 PM
Cory
Aug 20, 2006 09:09 PM
HD Renegade
Apr 16, 2006 12:44 PM
