I have been reading some threads about powdercoating vs eopxy paint. Need some opinions. I want to black out some of my bike. I am leaning towards epoxy paint because I am reading it is pretty durable and less expensive if done correctly.
Here are the parts I would like to black out: triple trees, fork sliders, strut covers, removable sissy bar, luggage rack, and turn signals.
Will these parts hold up if I paint them or should I pay the extra $$$ and have them powdercoated?
i woudl powder them... but the lower legs and turn sigs dont really get to much beating up so you can paint those... mine have been painted for almost 2 years now with no issues... but the side covers i would def powder as well as the sissy bar and rack
If you can afford it powder coating is best.I painted my fork sliders with epoxy because I didn't have money for powder coating and didn't want the hassle of disassembling my forks just for something cosmetic.But think about it you can paint stuff now and if you're not happy with the way it turns out still have it powder coated later.It has to be stripped for powder anyway.Of the things you mentioned the fork sliders and strut covers are a good candidate for Epoxy because they're easy to get to and redo if the paint gets scratched or chipped.I had a real tough time getting paint to stick to my turn signals and taking the triples off is something I don't want to do more than once.I don't think Epoxy would be tough enough for a luggage rack.
Small stuff epoxy paint (after good prep.) high abuse and wear areas powdercoat.
I tried the epoxy on my rear pulley but it was not really tough enough but worked fine on some shock perch covers. I use www.finaltouchpowdercoating.com for stuff I want to last (he has my pulley now) and he's fast plus reasonable.
I'd not used the epoxy paint before but plenty of other enamels which reguire primer (epoxy does not). The epoxy is very hard and tough once cured but in testing for longevity I tested a piece the I nicked and scratched (since the epoxy is not recommended for exterior use) and if you scrape or chip it by chance and it gets wet or you use a solvent cleaner or even wax/polish around it the paint will lift over time starting at the chipped area. The severe test was scraping a small area and letting the part sit in water for 10 minutes (not like washing or riding in rain would do this) when I run my finger over the paint it pushed right off but this was after only curing the paint for 2 weeks (epoxy paint supposedly cures in 24hrs. and recoat only after 1 week).
Epoxy has great resistance to moisture as was stated earlier but almost no resistance to UV damage. I wouldn't use epoxy as a topcoat if your bike is outside a lot. You didn't say if you wanted gloss or flat. If you are looking for gloss I would go with a urethane. You can do flat with the urethane but it will take a lot of flattener to pull it off.
off.
Ditto on the fact that epoxy has no UV resistance!
There is a "paint" called Endura this was developed for use on highway trucks and heavy equipment, it is nearly indestructable, a bit pricy but quality costs --as to sellers --- Google the name and good luck
