Heavy Breather
Old Jan 27, 2009 | 12:50 PM
Thornhammer's Avatar
Thornhammer
What I've heard is that the Heavy Breathers don't really provide any real performance gain over a regular Stage I kit unless you do some serious engine work, at which time the Heavy Breather kit takes the lead.
Old Jan 27, 2009 | 12:56 PM
drtheo's Avatar
drtheo
Not to hijack the thread, but have you guys that have the heavy breather and the x product noticed a difference, I wonder how the SE stage I with the x and the heavy breather with the X would compare?
Old Jan 27, 2009 | 01:02 PM
creekhed1's Avatar
creekhed1
Me Like-ee my Heavy Breather. Performs AWESOME!
Old Jan 27, 2009 | 01:29 PM
MLWilson's Avatar
MLWilson
Can someone please explain how a Heavy Breather takes over after serious engine work is done?
I would agree with above quote, numbers or first hand recommendations would be useful.
Old Jan 27, 2009 | 01:56 PM
wbeem's Avatar
wbeem
I'm doing some serious engine work on my new Fat Bob and asked the guys at the shop about this Heavy Breather. The consensus was that it's all for Show, not Go.
That doesn't mean it won't function better than the standard air cleaner; just that it doesn't provide performance better than a high flow air cleaner that fits inside the cover.
Given those statements, I decided not to get it. Yes, I actually do like the look, but we get a lot of rain in Florida and I know I'm going to get caught in a few downpours. I don't want to have to deal with some sock over the cone, so I elected to get a regular high flow air cleaner that comes with my Stage IV kit. I don't think you lose anything by getting this one. It's just more a matter of taste and preference than performance (or so I was told).
Old Jan 27, 2009 | 02:13 PM
rounder's Avatar
rounder
Originally Posted by jstreet0204
Not giving you a hard to but were they write ups in magazines where the product is also advertised? I've seen hundreds of positive dyno results on products that are pure junk. I would put more faith in an independent forum member that did a write up and dynoed the product before and after the install on the same day. That is about the only thing that would keep me from believing this is just another snake oil product. Seat of the pants results are often more the result of the reduced weight in the wallet than the product itself
so you have the conspiracy theory that they doctored the results? Ok 2 forum members say that it works in this thread alone (3 if you include me), there you go.
Old Jan 27, 2009 | 02:25 PM
rounder's Avatar
rounder
yeah, your carb/throttlebody and engine can only intake so much air and use it. If the intake system meets or exceeds these requirements, more air will not help. However utilizing different intakes that will smooth out the airflow is of an advantage. This is why some systems have the velocity stack. Guys on the track looking for peak performance often have to experiment with one intake system over the others to maximize their particular engines HP and torque. The x-wing improves the way the air flows through the intake to allow the engine to better utilize it. I dont think the heavy breather does that.
Old Jan 27, 2009 | 02:36 PM
creekhed1's Avatar
creekhed1
One thing's for sure...with a Heavy Breather you won't have to worry about NOT getting enough Air!!!
Old Jan 27, 2009 | 02:48 PM
SigEpRider's Avatar
SigEpRider
Personally, I could not stand the look of he football cover on my 09 street bob. So the high flow filter was never an option for me. I went with the heavy breather for the cool factor after I saw it on a bike at the he dealership. Especially because it comes in black, which is the new chrome. I now have forward controls with no clearnce problems with my right knee. I put the pipes, fuel management, and intake right away after I almost got ran over twice in the same day. So I can't really say if there was a huge difference in power based on feel alone. IMO it was worth the investment
Old Jan 27, 2009 | 03:01 PM
hardrider's Avatar
hardrider
Thumbs up
OK, I'd like to chime in. The turbonator's creator designed the device not to increase air flow but to create turbulance into the manifold. It does not work and in my opinion is a POS product designed for one thing; generate money. The problem with the heavy breather is although it is in direct contact with air flow it does nothing to increase that air flow and is in reality more inefficient then having an air cover which purpose is to collect and channel air into the filter at a higher velocity.
The Boyssen X-wing purpose is to increase the velocity of air at the throat and manifold where it will maintain it's pressure, in effect acting as an extended venturi. The X-Wing accomplishes the purpose for which it was designed and is an excellent stand alone product which in fact works as advertised.
Before some Adam Henry accuses me of being an agent for Boyssen, I am not and no way affiliated with the after market industry. KEVIN.
