Mounting fuel tank emblems
Old Jan 29, 2009 | 11:56 PM
rockon's Avatar
rockon
Put tape around the ones that are already on there, pull them off, then put the other ones in the empty space.
At least that's how I'd do it...
Old Jan 30, 2009 | 12:48 AM
BluBob's Avatar
BluBob
I have denim paint and lightly drew on it with a mechanical pencil. Wiped right off. Mount the first one, then measure it top, bottom, fore, and aft from known points like the dash, filler cap, bottom of tank, or rear of tank, then mark the placement for the other side per the same measurments. Just make sure you form them to the tank before you pull the backing off the adhesive. Good luck.
Old Jan 30, 2009 | 10:38 AM
coachstorms's Avatar
coachstorms
Default Thanks!
Thank you for all the help, think I got them as straight as they can be.
Old Jan 30, 2009 | 11:19 AM
manofsteele2003's Avatar
manofsteele2003
Yeah I got the same ones and the contour of them makes them really only fit in that little area. Mounting the first side is easy but getting the second one in the exact position on the other side is a little more of a pain in the butt.
Old Jan 30, 2009 | 01:57 PM
Ratbob's Avatar
Ratbob
Exclamation Roflmao
Originally Posted by coachstorms
i appreciate any help at all...well not any help because I took joe's advice before and when i peed on my stock emblems it did not make them easier to take off, but if you ever want to know how to clean **** off a bike pm me.
Always wondered who put the JRK in Joe!
Old Jan 30, 2009 | 07:00 PM
jwlehman's Avatar
jwlehman
I know you have them on now...but I if I ever replace mine I will probably try to use pieces of string to measure the location once I have one of them mounted to get the other one in the exact same location.
Old Jul 7, 2009 | 07:28 AM
gilbertpsk's Avatar
gilbertpsk
Originally Posted by dyna rider
I know it sounds stupid but they really only fit one area well. At least mine did.
I just bought the same emblems that you have in your picture. I hope they're as easy to install as you say. I don't want to look ate up!
Jayroney74
Apr 29, 2013 06:32 AM
LuckyKnuckles
Apr 19, 2012 04:49 PM
the reverend
May 8, 2010 01:40 PM
xFreebirdx
May 22, 2008 10:08 AM
waterman7474
Aug 31, 2006 02:00 AM
