I have a question?
I noticed that the service manual is written in such a way as if the speedometer could never fail. Well I determined it was the speedometer and brought it into the dealer and told them the above. They had the bike for two days and the service manger told me they found the problem, he said it was a wet wire, I asked if he meant a connector and he confirmed it was a wet wire
. I told him the wires are insulated and they could be submerged in water and it wouldn't cause a problem, he got a dumb look on his face and suddenly had a loss for words.He also wanted to charge me eight hours labor for diagnosing the problem (wet wire
), until I called Harley Davidson and complained, then I got a call from the dealership telling me that the bike is ready to be picked up and it was covered under warranty. Riding home, engine light came back on, codes set. Lost all confidence in the dealership and bought some Screamin Eagle gauges on line. No problems since.So first thing would be to check your codes, that might point you in the right direction, also look into the speedometer sensor on the trany.
Engine Light function: Normal operation=light comes on for four seconds after IGN SW on, then goes out if no present DTC. DTC in History=light comes on for four seconds after IGN SW on, then goes out, then comes on for eight seconds, then goes out. Current DTC=Engine light stays on after IGN SW on indicating current fault (note: some codes will only trip at engine run i.e.: CKP)
WOW Test: To access function, hold in speedometer trip reset button while turning on IGN SW to ignition or run (engine start/stop sw must be in RUN position).
P=ECM DTC S=TSSM Sp=Speedometer St=Tachometer (if equipped)
*Part number of component follows each item after pressing reset button.
