going to open my cam cover tomorrow and inspect my tensioners as well as install a baisley spring.. manual says torque cover bolts to 120 "inch" pounds.. i only have a 3/8 torque wrench thats in "foot" pounds.. will i be ok just torquing to 10 foot pounds with the bigger wrench, or would i be better off getting an inch pound wrench.. dont want to break a bolt lol.. im thinking just torquing to 8 foot pounds.. which is about 100 inch pounds..
thanks!
thanks!
I wouldn't trust the footpounder to read accurately that low on the scale.
An inchpounder is a good investment.
Probably more important to follow the torque sequence
and *snug* down good with the blue locksnot applied.
thanks!
120 in/lbs = 10 ft/lbs, however when using low torque values like that you are much better off using an in/lb torque wrench just for the resolution. But still, just use common sense and you will be okay.
