tri bar on fatbob installion help
Old Feb 21, 2009 | 02:53 PM
bastardsuns's Avatar
bastardsuns
Default tri bar on fatbob installion help
before i even get out the hammer and chissel, is there any one who could give a little input on the installation, thanks fella
Old Feb 21, 2009 | 05:15 PM
maniac cop 5's Avatar
maniac cop 5
It's pretty straightforward. The only problem I had was getting enough slack in the wiring harness under the fender to make the connections. You have to cut a tie wrap under there and I just couldn't get to it without taking my fender loose. Would have been fine except I scratched the fender slightly putting it back in. If I'd have put the bike on a jack for more clearance or had an extra pair of hands helping me I wouldn't have had any problems. Still all in all, nothing to complain about. Just get something comfortable to sit/ lay on and have good lighting (I didn't) and you'll do fine.
Old Feb 21, 2009 | 05:26 PM
BusyHunter's Avatar
BusyHunter
+1 on taking the fender off. Do that at the start because you will need to clip the wire ties on the harnes under the fender in order to pull it towards the rear to get some slack. Seems like they flipped the mounting of the connection block so you need a good two inches more towards the rear. (at least on my bike). Other than that, it's really straight forward.
Old Feb 21, 2009 | 05:27 PM
bastardsuns
the way im seeing its that you have to tear that whole *** end out, what does the jack do to make it easier, sorry but to me this is rocket science
Old Feb 21, 2009 | 05:34 PM
maniac cop 5
If you jack the bike up I believe you'll get a little more clearance between the tire and fender to get to the tie wrap. I didn't have a jack so I'm just guessing here. I think some specialty pliers like hobbyist pliers would have an easier time cutting the tie wrap than just regular mechanics type. After I finished the job, I even thought that toenail clippers might have cut the tie wrap without my having to remove the fender. That's all the good stuff you think to do AFTER you've done it the hard way! LOL!
Old Feb 21, 2009 | 09:46 PM
HD Jake's Avatar
HD Jake
I did mine and used a lift (jack) it just gave me way more room under the fender to get my mitts in there.
I did not remove the fender and did the entire thing in about 45 mins, clipping the wire tie was the hardest thing to do
Old Feb 22, 2009 | 02:24 AM
Fatbob Pharoe's Avatar
Fatbob Pharoe
+1 on clipping the wire tie. And absolutely no need for a jack.
Old Feb 22, 2009 | 07:44 AM
bastardsuns
just curious as to what i will have to remove
Old Feb 22, 2009 | 08:16 AM
SC-Longhair's Avatar
SC-Longhair
Did the light come with any install instructions?
Old Feb 22, 2009 | 08:26 AM
bastardsuns
it came with assembly instructions for an entertainment center, it should be stock with the bike, no pride in product anymore
