changing rear shocks.. question?
Old Mar 8, 2009 | 09:10 AM
08FXDC's Avatar
08FXDC
Default changing rear shocks.. question?
Alright, I did a search to see if i could come up with a torque number for the upper and lower bolts for my rear shocks when i change them. I got several different numbers that were all over the place from several different people.
Does anyone know the accurate numbers for this on a 08 dyna superglide custom? The shocks are off a streetbob if it matters.
Also kind of stupid question, but i figured i asked before I buy a jack, do I need a bike jack to do this or can u get away with changing them one at a time with the bike on the kickstand? I figure not, but why not ask.
Thanks for the help!!!!
Old Mar 8, 2009 | 09:19 AM
Toypuller's Avatar
Toypuller
Upper bolt 75-85 Ft/Lbs
Lower bolt 30-40 Ft/Lbs
You can change them without a jack. Just remove them one at a time, have to lift and push just a little.
Old Mar 8, 2009 | 09:28 AM
skankaholic's Avatar
skankaholic
I changed mine without a jack. No issues. Take your time!
Old Mar 8, 2009 | 10:25 AM
archergodwin's Avatar
archergodwin
Both upper and lower are set at 30-40ft/lbs.
The 70 to 85 is only for the upper mount stud, not the nut holding the shock in place.
People probably have done them one at a time on the kickstand, but I'll bet they turned the air blue around them at the same time. I would recommend the jack stand, makes the job so much easier.
lowend73
Aug 28, 2013 03:28 PM
magnum629c
Jan 28, 2013 04:20 PM
ZeroFiveFour
Feb 26, 2011 10:15 AM
Harley43147
Nov 18, 2009 11:52 AM
shekmark
Mar 16, 2009 08:13 PM
