Removing Shocks
Old Nov 18, 2009 | 09:43 AM
Harley43147's Avatar
Harley43147
Cool Removing Shocks
Hi All.
As a winter project I'm looking at upgrading my shocks on my 08 SB. Do I have to lift the bike up, or can I swap them out one at a time? Thanks!!!!
Old Nov 18, 2009 | 09:49 AM
2007fxdc's Avatar
2007fxdc
Are you going with the same length shock? If so, it might make it easier to do one at a time than if you go with a different length. You still want to lift the bike up to take the load off the shocks. I went with a shorter shock so I lifted the bike up, and put something under the rear end so the swingarm doesn't drop further than it needs to. I removed both shocks and then mounted the new ones as follows:
Mount the new shocks to the top and then lower the bike enough to line up the bottom holes and install the lower bolts. Be sure to use loctite and torque your shock bolts.
If you have rear pegs, make sure you remove the right side peg mount to make sure it doesn't hit your exhaust when you let that swingarm down.
Old Nov 18, 2009 | 10:23 AM
Harley43147
Thanks 2007fxdc. I was hoping I wouldn't have to buy a lift :-(
Old Nov 18, 2009 | 10:36 AM
2007fxdc's Avatar
2007fxdc
I hear ya. A lift is nice to have if you are going to wrench your own bike and is sometimes required. You might be able to figure out another method but imagine removing one of the shock bolts with the shocks compressed - especially when that bolt is almost all the way backed out - not fun.
But, regardless of what some other people think around here about it, I caught the Sears Red lift on sale for $59 a couple of years ago and it has served me well. But I don't use a lift all that often.
Old Nov 18, 2009 | 10:42 AM
BoomerBob's Avatar
BoomerBob
A lift and a service manual are two of the best investments that pay for themselves very quickly.
I picked the aluminum one from Harbor Freight and I use it several times a week on one or the other of the two bikes. Simply cleaning the wheels and doing some maintenance is waaayyy easier with a lift.
Harley43147
Smile
I think you're right and I need to invest in a lift. Thanks again!!
Old Nov 18, 2009 | 11:42 AM
grbrown's Avatar
grbrown
You will probably find the new shocks are not exactly the same length as the old ones, so you will have to adjust the distance between the fixing points. I wouldn't try changing shocks without a jack, but you don't need anything more fancy than a scissor jack or trolley jack, if you take care.
Old Nov 18, 2009 | 11:52 AM
nevil's Avatar
nevil
I changed my shocks on my 07 SB to 11.5" (half inch shorter than stock). Just did one side at a time and had no problem.
zeke7142003
Apr 19, 2018 08:42 AM
magnum629c
Jan 28, 2013 04:20 PM
cHarley
Mar 12, 2007 05:21 PM
IslandStorm62
Nov 7, 2006 10:32 AM
Ragin_Republican
Apr 19, 2005 03:57 AM
