Problem Getting into Neutral.
Old Mar 16, 2009 | 10:07 AM
DeathProof72's Avatar
DeathProof72
Default Problem Getting into Neutral.
Not sure if I have a problem, or just that I am not used to my transmission.
I have less than 100 miles on my 2009 FXDB and what I notice is that it is really tricky to get the bike into neutral, from second gear, usually miss it, from 1st gear, only the lightest of touches will put the bike into neutral, otherwise I end up back in 2nd.
And last when shifting from Neutral to 1st, just clicks into gear quietly, no loud clunk line other bikes I have ridden.
Just curious if this is all normal..
Old Mar 16, 2009 | 10:14 AM
Phrogman's Avatar
Phrogman
I had issues finding neutral on my 09 Fat Bob, up until I did my own 1000 mile service. I found that the clutch cable was way out of adjustment. Once I properly adjusted the cable and set my end-play at the lever, she slides right in to neutral.
Basically, the clutch was never set right during initial setup of the bike.
Old Mar 16, 2009 | 10:17 AM
ratt196635's Avatar
ratt196635
yes it normal you will get better at it. i almost never get it from 2ed.
Old Mar 16, 2009 | 10:19 AM
DeathProof72
Mine was checked, but before I rode it, and I mad mentioned that I wanted less pull distance, and even though they said it was within specs, I think they adjusted the lever in a minute distance. Could that be it? How hard is it to adjust? How can I test specs?
Old Mar 16, 2009 | 10:20 AM
DeathProof72
Does yers clunk from neutral to 1st? Or just a quiet click? My CBR 900 and other bikes had a more definitive sound when the bike was in first from neutral, so maybe they are just different?
Old Mar 16, 2009 | 10:22 AM
ratt196635's Avatar
ratt196635
quiet most of the time clunk ever once in a while
Old Mar 16, 2009 | 10:35 AM
Phrogman's Avatar
Phrogman
What really needs to be checked is the engagement of the ramp and ball assembly in the tranny. This is done through the derby cover on the clutch hub. I highly recommend you get the maintenance manual and follow the procedures in there for adjusting the clutch, but here is a run down.
1) Basically, what you do is create slack in your cable, run it all the way out.
2) Open up your derby cover. Then, loosen the 11/16" (it may actually be a metric size now, not sure, I still use an 11/16" wrench) nut at the center of your clutch hub.
3) There is an allen headed screw in the center of said nut. Once the nut is loose, turn the allen screw in until all free play is removed (do not tighten it, just turn it in until you feel it bottom out).
4) Now back the allen screw out 1/2 to 1 turn (I stop at 1/2 turn, backing off more will change where your clutch engages/disengages at the lever and can be set to personal preference).
5) Hold the screw with an allen wrench while tightening the 11/16" nut. I'm not at home, so I don't remember if there is a torque value, but it's basically just a set nut anyway.
6) Close up the derby cover
7) Tighten cable until there is 1/16" to 1/8" free play at the lever.
If you are not doing a fluid change while doing this, make sure the bike is level while your derby cover is off or you will leak primary fluid.
Old Mar 16, 2009 | 12:23 PM
DeathProof72
I think I am going to bring the bike in for service. Since it is under warranty and I live close, no harm done in that. Wonder about more opinions out of curiosity. Seems one of you has my issue, while the other does not..
Old Mar 16, 2009 | 12:30 PM
Nickpisp's Avatar
Nickpisp
Mine was the same way, I got used to it.
twentyfivemike
Jul 28, 2017 11:09 PM
graphicdisaster
Mar 27, 2017 08:31 AM
Nick 93
Sep 16, 2016 08:10 PM
2015 Harley Davidson Street Bob Guy
May 22, 2015 06:54 AM
Scionic Wraith
Apr 21, 2010 12:02 AM
