Need help with stage one air cleaner install
Old Mar 18, 2009 | 07:08 PM
jake40ma's Avatar
jake40ma
Default Need help with stage one air cleaner install
Guys,
I'm putting on FuelMotos stage one A/C and have one question: There is some sort of sensor wired into the plastic stock backing plate. What do you do with that once you unplug it? These directions are very vague. Hopefully Im doing this right. Please help!
Old Mar 18, 2009 | 07:17 PM
ackman1968's Avatar
ackman1968
Just tie it up out of the way, it is un-used on US models.
davidc's Avatar
davidc
My SE kit had a clip to put on the back plate to hold it. The plug is jumped out, it doesn't do anything so you could just zip tie it out of the way.
Old Mar 18, 2009 | 07:27 PM
K9pusher's Avatar
K9pusher
I second the zip tie. Worked for me.
Old Mar 18, 2009 | 07:32 PM
jake40ma's Avatar
jake40ma
thanks fellas I'm on it!!
Old Mar 18, 2009 | 07:47 PM
SC-Longhair's Avatar
SC-Longhair
This is also a very searchable topic.
Old Mar 18, 2009 | 07:49 PM
anubisss's Avatar
anubisss
The plug is used on European models only.
Old Mar 19, 2009 | 06:13 AM
jake40ma's Avatar
jake40ma
Default last stupid question
I reinstalled the stock a/c cover. There is a rubber trim over the semi sharp edges of the football. This seems like it will fall off easily.How have you guys dealt with this or did you just toss it? It used to sit tight against the old platsic backing plate.
Old Mar 19, 2009 | 07:25 AM
harleytuner's Avatar
harleytuner
Toss it. I suppose if you wanted to keep it on there you could use some silicone, but i'd just 86 it.
clyles
Mar 4, 2015 03:02 PM
Lwood Classic
Mar 25, 2012 08:56 PM
01flhtc
May 14, 2011 04:48 AM
rockon
Jan 28, 2009 04:58 PM
oscarg
Mar 29, 2008 11:04 AM
