Cams??
Old Mar 20, 2009 | 09:57 AM
abearcarver's Avatar
abearcarver
Default pulling the cam bearing is a bastard
pulling the cam bearing is a bastard if you dont have the correct puller .. the **** of it is the bearing is $10 and the puller $85 .. If you f%&k up you will damage the bearing and it will fall apart and then its a real hard job to file, chesel, tap, wack, pull that dam thing out of there without destroying the block .
Old Mar 20, 2009 | 10:10 AM
SC-Longhair's Avatar
SC-Longhair
Thats the bearing on the inside of the cam chest? The tool is this plate that fits over the outside of the cam chest, bolts down and then a threaded rod pulls the bearing out?
Ya know, I was wondering how many of y'all have acquired the tools and would be into doing a trade program. Maybe kick up $5 towards overall cost to the person. Sort of a rental fee.
We're all upstanding guys here. How many times you gonna change cams in your life?? Don't answer that.
Old Mar 20, 2009 | 10:14 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Originally Posted by rockon
I'm probably gonna pull on some Wood gear-driven cams in the next 6 months or so...as with everything else on my bike I'll be installing them myself...hopefully getting the tune right afterwards will hopefully be a fairly easy process with the Thundermax setup.
I talked to Zippers about this a few weeks ago. They said no need to change maps. Clear all your learned offsets and go ride, the Tmax will take care of the rest.
Old Mar 20, 2009 | 11:36 AM
CRF's Avatar
CRF
not sure about cost but I'm thinking of doing the same thing....did some research and the cams that seem to be the front runners are the Woods TW-6-6 and the HQ 500
Old Mar 20, 2009 | 01:48 PM
rockon's Avatar
rockon
Nice. Thank for the info!
Old Mar 20, 2009 | 02:48 PM
paul s's Avatar
paul s
I just ordered the Andrews 37's for $228.90 shipped. I'll put them in myself, I know how to wrench but I'm new to Harleys so I've been studying the threads here on cam changes and it really is a simple job.https://www.hdforums.com.au/Default....ics&forumid=24 Scotty does a good job of showing the install.
kryingame
Jan 15, 2019 02:54 PM
Notgrownup
Sep 19, 2010 08:28 AM
newrench
Sep 29, 2008 08:57 AM
sportyrider1
Nov 2, 2007 07:46 PM
coriell43
Sep 18, 2006 04:20 PM
