Next little mod....
Old Mar 29, 2009 | 09:40 PM
archergodwin's Avatar
archergodwin
Originally Posted by jb27
Nice work, looks good!!
I'm planning on doing that too. Is it an easy install? Any tips/tricks? I'm a rookie wrench.
Looks good! How did you like doin the switches? Mine were a PITA!
They weren't too bad. Just have to make sure the switch caps are 'started' correctly, then they snap in fairly well. I was actually surprised that the housing kit came with everything I needed, inlcuding new tie wraps.
jb- make sure you have a good torx set, and a "large" flat blade jewlers screwdriver... (oxymoron there.) less than .1 wide tip. Works well to pry the old caps loose. Left side, not so bad. Right side... lots of little pieces that can get lost. Make sure you have time... they take some patience.
Old Mar 29, 2009 | 10:21 PM
ackman1968's Avatar
ackman1968
So should I feel bad about 60 degrees and sunshine?
Old Mar 29, 2009 | 10:29 PM
archergodwin
You can feel as bad as I would, should the tables be turned
Old Apr 1, 2009 | 10:41 PM
ackman1968's Avatar
ackman1968
The tables didn't turn but I pulled up a seat with you. This is from this afternoon, thankfully I live at a little lower elevation.
Had to take a picture, my wife though I was yanking her chain being April fools day.
Old Apr 1, 2009 | 11:17 PM
archergodwin
Yeah, I'm getting tired of this ****..... suppose to be about another 5" tonight...
... oh well..... installed the easy bracket mounting points tonight.... will probably hook up the tuner tomorrow night
RSmokos
Nov 17, 2014 08:44 AM
hinerj
May 24, 2011 10:13 AM
njhonker
Apr 17, 2011 03:08 AM
bambamblazer
Mar 10, 2009 07:42 PM
SOCALHD
Apr 6, 2008 01:41 PM
