relocation kit for 2009 dyna
Old Apr 3, 2009 | 10:59 AM
zman013's Avatar
zman013
Default relocation kit for 2009 dyna
I bought a 2009 super glid custom, I want to put the detachable sissy bar on it but don't want to move the turn signals. If anyone has gotten around this please let me know. Thanks for any help.
Old Apr 3, 2009 | 11:23 AM
rockon's Avatar
rockon
If you want to use the detachable kit, you have to use the relocation kit, which doesn't move them off the struts, but has an adapter that allows the detach sideplates to snap onto the mounting bolt.
Others have bought the rigid sideplates, dremeled out the mounting holes, and used that. Looks a little cleaner, and I don't think requires the relocation kit because it mounts inside the struts (don't quote me on that though).
Old Apr 3, 2009 | 11:30 AM
Grind's Avatar
Grind
I'll quote you on it. I've done it (notching rigid sideplates) to mine. No turn signal relocation required.
Old Apr 3, 2009 | 11:36 AM
OhioSkully's Avatar
OhioSkully
Here are a cpl pics of the kit that relocates them and keeps them in the same spot. It doesn't put them out any further than the original. Now if you plan to add saddle bags you will need to move the signals off the struts.
I had the rear laydown plate relocation kit and ended up putting a side plate on and moving the signals back to the struts with the quick detach sissy bar relocation kit.
Here is pic of the laydown plate relocation kit i used to have.
Old Apr 3, 2009 | 11:41 AM
rockon's Avatar
rockon
Old Apr 3, 2009 | 12:13 PM
zman013's Avatar
zman013
thanks for the information everyone
Old Apr 3, 2009 | 12:31 PM
zman013's Avatar
zman013
Do you have a part number or kit number for the kit you used, thanks for the pic and reply
Old Apr 3, 2009 | 02:04 PM
HD 472's Avatar
HD 472
Had I known I had to cut the wires on my blinkers for the removable backrest .......I would have relocated them back by the tail light.....Easybracket and Harley has relocator kits. Then the question of saddlebags might not come up......Just an option........ And easybrackets are easy to put on I seen thier video online...
Old Apr 3, 2009 | 03:27 PM
08FXDC's Avatar
08FXDC
check with your dealer to be sure, but I BELIEVE this is the part# 53968-06C
Im pretty sure this is the kit that's on my dyna which is the same kit ohioskully has.
patsfan05488
Jul 3, 2010 07:18 PM
odddaysarefun
Aug 6, 2009 11:12 PM
dawg8037
Mar 26, 2008 03:20 PM
boogerbooger
Jan 5, 2008 11:19 AM
millermeteor
Apr 5, 2007 05:22 PM
