Fork Lock
Old Apr 11, 2009 | 11:29 AM
WS6 Formula's Avatar
WS6 Formula
Originally Posted by Rauzer
I had an issue last year where it wouldnt lock them at all. When looking up where the pin comes down, the hole is elongated, front to back. The pin on my lock had moved to the back and was missing the holes in the tree to lock the forks. I stuck a screwdriver up there and it moved forward. I havent had an issue since. Maybe thats not exactly your issue, something to check for tho. I also just spray WD-40 right into the lock where the key goes, makes it work real smooth.
Same here, also if you turn your key without the handlebars turned all the way to the left, and the lock pin is protruding, it will get pushed out of alignment by the lower triple clamp. The lower triple clamp kind of has a low cam profile to it, where as you won't feel much resistance when turning the handlebars while pushing the pin out of alignment.
Old Apr 11, 2009 | 02:16 PM
ackman1968's Avatar
ackman1968
Originally Posted by Wrongturn
My bike started doing exactly the same thing about 2 weeks ago. Haven't had the inclination to either take apart he lock or hit the dealer up about it.......but 1k service coming up and i'll take care of it then. Been wrestling with the idea of doing the 1 k service myself. Whats the quickest way to find out if my bike is under warranty? Its an '07 that i bought used from the dealer and i was so excited about getting a good deal on the bike that i didn't even ask about the original purchase date.
There is a page on the Harley web site where you can type in the vin for service work. It may tell you there if you have warranty and for how long.
Old Apr 19, 2009 | 08:13 PM
maddghost's Avatar
maddghost
I thought this was funny until it happened to me today! Luckily I had read through the thread,took a screw driver and slowly pryed the lock pin towards the front wheel,all good now! Thanks to all the bros!
Holywater
Sep 14, 2021 07:54 PM
Livnoutdoorsxd9
May 27, 2015 03:34 PM
47909Rider
Jul 2, 2013 07:55 AM
Handycam
Apr 11, 2011 07:00 PM
Bluerose
Mar 13, 2008 04:02 PM
