Install power commander
Old Apr 12, 2009 | 08:06 AM
Jessie's Avatar
Jessie
Question Install power commander
Hey Guy's I spent 3 hour's last night trying to install a power commander I got it all hooked up and could not fit the center screw on fuse box and had unit hanging out by belt guard no way my 07 super glide custom so I took it all off and gave up there is not enough room in there the plug's are in the way inside any help would be appreciated there is no way you can Velcro it to the bottom of the box there is not enough meat for it and the anti theft stuff under the seat this is driving me nut's the stealer wants 150.00 and up so I need help I cant get the box to come to far away from frame also so it is very tight ?
Old Apr 12, 2009 | 08:40 AM
davidc's Avatar
davidc
If you can't get the center screw in the fuse box in it is probably becuase a wire is in the way and if you force it you could pinch it and have a short. Take the battery box out it makes it easier. Is it a PC III or V, the V fits right under the seat.
Old Apr 12, 2009 | 09:05 AM
SC-Longhair's Avatar
SC-Longhair
PCIII will fit under the seat too....just need to move things around carefully and mash it in there.
Old Apr 12, 2009 | 09:37 AM
BluBob's Avatar
BluBob
Take a look at the install video on FuelPak's website, it may help. I fit my PCIII under the ECM, and have the main plug under the seat. I don't see how you can fit both under the seat.
Old Apr 12, 2009 | 09:53 AM
SC-Longhair
If I remember, I didn't put both the pcIII and connectors under the seat. I was able to get the connection down near the ecm and the pcIII is under the seat. Just takes a little work.
Think about it. To do any updates to the pcIII, you have to remove the seat before removing the side cover. Why not just put it under the seat and ONLY have to remove the seat to make updates.
Old Apr 12, 2009 | 10:01 AM
JayStronghawk's Avatar
JayStronghawk
Just helped a Buddy do a PCIII fit under the seat on his Dyna just took a little finesse..
Old Apr 12, 2009 | 10:04 AM
Jessie's Avatar
Jessie
It's a PCIII USB and the center screw had the ecm and pcIII plug in the way and there was no way around it in the top is the anti theft stuff so I just took a second look and I just cant see it ! Thanks Guy's JT
Old Apr 12, 2009 | 10:10 AM
MNrider's Avatar
MNrider
There is a trick to it. I put a mustang vintage seat on yesterday and had to move the pcIII from under my seat to under the ecm like they say to do. You're right, it's tight in there. I don't have the security , but here's a trick you can try.
Make sure the PCIII usb port is towards the rear tire with the big cable wrapping underneath it. You'll need to tuck it all in from the right side of the fuse box. So after you get all those PCIII wires pushed back in there, pull the gray one through and connect it to the ecm. Connect the stock gray plug into the black PCIII plug. Now the tricky part. If you look to the right of the fuse box, you'll see the frame bar running down from under the tank and angles down below the seat. Carefully push the gray and black plug connection in front of that angled piece of the frame. Keep the PCIII right under the ecm, i did not velcro it. Then before you side it all back in, look down through the seat hole and look for any wires that will block that center screw that you could not get to thread. Carefully push the wires out of the way and push the fuse box back in place. Put in the 2 top screws and tighten, but not all the way tight. Take a flashlight and look into that center screw hole to see if there is anything in the way and that the hole is lined up. If it's clear, you're good to go, if not, you may need to take the top 2 screws off and move the wire again. Look at the pdf on their site, and look closely at the pics of those 2 big connectors and you'll see what i mean about putting them in front of the frame.
I hope this helps.
Old Apr 12, 2009 | 11:07 AM
roadhouse's Avatar
roadhouse
its a fight till the end. very tight. if u take the battery out ull be able to get a better look and more room to play with.
AFblacksheep
Jan 22, 2010 05:24 PM
dglong
Oct 30, 2008 11:22 AM
Jessie
May 11, 2008 03:00 AM
FGC
Feb 24, 2008 05:37 PM
dj4016
Sep 11, 2006 09:21 PM
