FXDC Stock wheel compatibility
Old Apr 13, 2009 | 07:29 AM
2007fxdc's Avatar
2007fxdc
Default FXDC Stock wheel compatibility
Looks like I'm going to just put my stock spokes up on ebay and see what I can get for them. Can someone in the know tell me exactly which years and models that they should be a bolt on replacement for?
Old Apr 13, 2009 | 05:55 PM
jmpancoast's Avatar
jmpancoast
I would start the bidding at the minimal you will take for them and let it go up from there through the bidding process.
They will only fit 06-07 mid-glides (FXDI, FXDC, FXDB, FXDLI).
Old Apr 13, 2009 | 06:09 PM
Speedracer7c's Avatar
Speedracer7c
why wont they fit the 08-09 years?
Old Apr 13, 2009 | 06:18 PM
Gary7's Avatar
Gary7
Bearing size is different.
Old Apr 13, 2009 | 06:19 PM
jmpancoast's Avatar
jmpancoast
08 and up have 25mm bearings. 06 - 07 use 1" bearings.
Old Apr 13, 2009 | 06:26 PM
Speedracer7c
you can't swap bearings?
Old Apr 13, 2009 | 06:30 PM
Gary7's Avatar
Gary7
If you can fit a 25 mm bearing into a 1" race.
Old Apr 13, 2009 | 06:31 PM
Speedracer7c
well I didnt know if it was the id or the od that was different.....
Old Apr 13, 2009 | 06:34 PM
AdrianVall's Avatar
AdrianVall
Doesn't harley sell a kit, or something of the sort, so that your able to switch bearings sizes?
Old Apr 13, 2009 | 06:39 PM
jmpancoast's Avatar
jmpancoast
Yes you can swap the bearings, if you want the extra expense and have the correct pulling tools.
The 1" and 25mm bearing measurements are the i.d. The o.d. is the same on both. The bearings are sealed so there are no separate races. The sealed bearings are pressed into the hub.
catch_kc
May 17, 2019 11:05 AM
1HD2NV
May 21, 2014 12:53 PM
ironalex
Oct 1, 2012 04:08 PM
ghostrider69
Sep 20, 2009 10:28 AM
Bluesrider
Nov 4, 2008 11:05 AM
