Terminal Velocity II or DFO
If I use the Terminal Velocity II it seems that I would not need any other system on my EFI and it would essentially make my system a WEGO system. Is this true. Do I have to do anything else on the 06 Dyna EFI system to use the TVII system as my Fuel managment system for Stage 1?
I am hearing more an dmore people saying use DFO instead of SERT, PCIII or V&H. That is is cheaper and works better. Any opinions?
Thanks.
Keep an eye out for the Daytona sensors dual o2 kit and I believe thundermax will have another one out this spring. These things are so advanced it's not funny.
The opinions you are reading on the TFI, DFO are almost worthless on the closed loop systems. The TFI 'aint so bad when adding fuel to the acceleration mode for a jump in performance but tuning the cruise mode is a compromise at best; problem is that you are trying to 'fix' a bad base map especially on the 06 bikes. I've run 'em both and can say that with a straight face. As a tuning tool (on the factory closed loop ECU) for a modified bike or even a bone stocker, the SERT is the best end of story.
If I weren't scared about screwing my warranty, I'd be all over one of the twin sensor WEGO systems so fast it's not funny.
The softail will need 02 sensors installed.
Stucarious, I'm right there with you man. I'm going to pick either the DFO or TVII.
I don't want to pay someone to do this. I'm leaning more towards the TVII. I believe using
the 02 sensors is the way to go. I'm only planning on stage 1 for my bike.
I do not understand why everyone is not doing this. That is the biggest hesitation I have. Is there something I am missing or is it just that since it is so new to have HD closed loop systems people have been making the wrong choice by just going with older systems for open loop?
Since I am getting Bassani pipes with a bung I might as well take advantage of the O2. It is a better system after all.
I don't like this idea but if it works as advertised.....
You won't be able to up the rev limiter either.
Since only the Dyna has 02 sensors the knowledge about these is probably
lagging. I am also concerned about getting failure codes and blinking lights in ECU.
Don't need a light show.
A while back some guys on here were getting a sample piece
from Terry but they did not report after installation. In the same thread there were a
couple of other dudes that reported that it seemed to work as advertised. I would also
like to know how the plugs look after usage.
I agree. One downside to the TVII is that you have to wire it into existing harness.
Make sure you read the FAQ's
This ecu supposedly works like the TVII but it replaces your current module so you don't have to
splice in wires. $695!!!!!!!!!!!!
I sent them an e-mail to see if it is cheaper for Dyna since you don't need the 02 sensors.
