vibration?
Old Apr 15, 2009 | 05:41 PM
vlad75's Avatar
vlad75
Thumbs down vibration?
hey guys, i have looked at the other posts regarding odd vibrations and i still don't have an idea. so here it is, i've got an odd virbration that isn't allways present, seems like i pick it up in third, and gets worse as you are on the throttle, it is also present when off the throttle and decelerating. it also goes away when the clutch is pulled. any ideas? i went for about a 4 hour ride last sunday and it wasn,t there, but yesterday and today i noticed it. any help is appreciated, thanks.
Old Apr 15, 2009 | 06:40 PM
dyna rider's Avatar
dyna rider
Default Vibes
If it goes away when the clutch is engaged, it has to be in the motor or drive train.
Old Apr 15, 2009 | 10:08 PM
nfccrwr's Avatar
nfccrwr
Could the shim for the clutch lever itself be missing. Does it happen when your hand is steadying the lever?
Old Apr 15, 2009 | 11:06 PM
EDZ82FXR's Avatar
EDZ82FXR
Did you check maybe all the mounts to see if any of them are going bad or have gone bad?
Old Apr 16, 2009 | 09:43 AM
dyna rider's Avatar
dyna rider
Default Vibration
Have you given any thought to it being the inner primary bearing ? Hope it isn't but it is a possibility.
Old Apr 16, 2009 | 09:45 AM
coppertop666's Avatar
coppertop666
Had an issue last season very similar and it turned out to be my front motor mount bolts were loose - check'em
ktp1598
Harley-Davidson Street
39
Aug 24, 2023 05:22 PM
jcanrun
Mar 12, 2021 07:40 PM
Jackpoticorn
Oct 7, 2016 10:29 AM
Ployd4
Sep 14, 2014 07:05 AM
MAX EVO
Nov 14, 2007 10:27 AM
