Custom Dynamics LED's pulsing
Old Apr 19, 2009 | 07:24 PM
Rauzer's Avatar
Rauzer
Default Custom Dynamics LED's pulsing
I have the Custom Dynamics LED turns and tail light. I bought the stop/turn module also for the rear turn signals, bought it all as a kit from them. First time I had it out in the dark, I notice that with the brakes on and the bike at idle, all my rear lights pulse with the engine. It only does it with the brakes applied.
I called CD tech support and they tell me, thats what they do. He said the LED's are picking up the little voltage spikes/dips with the bike is at idle. I held the brakes and took the RPM's up past idle and it stops pulsing. Is there something I can do about this? Anyone else experience this? Is my alternator/stator/battery on the way out?
The bikes an 06. Any ideas would be greatly appreciated. Thanks!
Old Apr 19, 2009 | 07:51 PM
fixxr's Avatar
fixxr
I belive there is a filter for that.You may have to ask someone at a "RadioShack"For that.Or you could try useing a sheilded wire that may also help.
Old Apr 19, 2009 | 07:53 PM
archergodwin's Avatar
archergodwin
It's entirely possible that it's no big deal. I mean, the alternator is not meant to charge at idle... it just won't. So I'm sure that there are rapid peaks and lows of the voltage, as the rotor turns within the stator at less than optimum rpm.
If it really bothers you, you might be able to install a large capacitor in the system to even out the voltage. Yeah, that's not really a good answer or solution though. But that's about the only way to even out the spikes.
Old Apr 20, 2009 | 03:40 AM
Rauzer's Avatar
Rauzer
Maybe I'll check with them. I dont think a shielded wire would be the answer as it doesnt seem to be picking up noise or it would be doing it at all rpms I think.
Old Apr 20, 2009 | 03:43 AM
Rauzer's Avatar
Rauzer
Maybe a capacitor is the way to go, tho I've got no idea where it would go lol. My worry is when I'm coming up to a turn and I have my blinker and brakes on, all the lights are flashing/blinking and you cant tell the blinker is really on.
Old Apr 20, 2009 | 03:54 AM
mikeurig's Avatar
mikeurig
What are your rpms when the bike is idling? I've used those CD led's in the rear along with Harley's brake/run/turn module and CD's load equalizer and didn't have a problem.
Are you using a load equalizer? Remove the brake/run/turn module and see what happens.
Old Apr 20, 2009 | 03:59 AM
Rauzer's Avatar
Rauzer
I have the load equalizer and the stop/turn module, all from CD. I have a Dakota Digital speedo with a bar tach so it looks to me that it idles at ~ 1000, maybe lower. The numbers are pretty close with not much room between, hard to tell the exact idle.
Old Apr 20, 2009 | 04:28 AM
mikeurig's Avatar
mikeurig
Now that those CD LED kits are DOT approved, I might install them along with a Kuryakyn LED tailight.
Old Apr 21, 2009 | 01:05 PM
Rauzer's Avatar
Rauzer
Bump to see if anyone else has some info.
Old Apr 21, 2009 | 01:37 PM
dyna07custom's Avatar
dyna07custom
I would think there is something wrong with the load equalizer those LED lights draw less than the factory incandescent bulbs. If they are pulsating so should your stockers
joe losacco
General Topics/Tech Tips
Jun 20, 2021 12:10 PM
MNFB70
Aug 13, 2011 06:26 PM
veegee
Oct 3, 2010 05:02 PM
ms3300
Jul 31, 2010 07:34 PM
ratleaker
Oct 31, 2008 06:33 AM
