straight pipe exhaust is it safe
Old Apr 20, 2009 | 03:19 PM
buyingbuyer's Avatar
buyingbuyer
1st Gear
Default straight pipe exhaust is it safe
I have FI wide glide with 1 3/4 straight exhaust and was wanting to change to 2" straigh back slash cut pipes , harley dealer said pipes I using now is bad for engine ,should have baffles and if I switch to the 2" straight pipe I have to have baffle or good chance of burning valves is this true and can I just put baffles in the 2" pipes and be ok
Old Apr 20, 2009 | 03:43 PM
maddghost's Avatar
maddghost
If you have straight pipes i imagine you like it very loud-so baffles will make it quieter and you don't want that I think. You just need some type of fuel management device like PCV, pcIII, sert,tts master tune, vance &hines fuel pak.... There are more...
Old Apr 20, 2009 | 06:11 PM
SC-Longhair's Avatar
SC-Longhair
Doesn't FI require a decent amount of backpressure?
Old Apr 20, 2009 | 06:13 PM
rockon's Avatar
rockon
Backpressure = Power
Straight Pipe = Noise
Power = Win
Noise = Fail
Old Apr 20, 2009 | 06:17 PM
paul s's Avatar
paul s
http://www.bigcitythunder.com/pages/...rformance.html These should do the trick.
Old Apr 20, 2009 | 06:49 PM
xxxflhrci's Avatar
xxxflhrci
It will run like crap with open 2" pipes. Save your money on that BCT crap and just get you a set of 12 buck shorty baffles. If you need to do any "tuning", make a pair of lollipop baffles and put them in either before or a after the shorty baffles.
Old Apr 20, 2009 | 07:37 PM
DMV11982's Avatar
DMV11982
Will I have to run a tuner with Vance and Hines Slip ons?
Old Apr 20, 2009 | 07:58 PM
the blob's Avatar
the blob
i run 1 3/4 inch drags on my 06 superglide. mine felt like a dog with no pipe mods
i had to drill holes in the bottom of the pipes and stick screws up in them. after that it made a big diff. in torq. I love the sound and looks be sure to get a tuner though.
Old Apr 21, 2009 | 04:09 AM
bklynbob's Avatar
bklynbob
Default try these
Khromewerks hp+ baffles.
Old Apr 21, 2009 | 09:00 AM
archergodwin's Avatar
archergodwin
No. When you change air cleaners later, yes.
