Fuel Pack Adjustment
My wifes FXDF has v&H short shots with V&H Quiet Baffles. I am even getting pops between shifts.
Anybody have any ideas?
http://www.fuelpakfi.com/harley1.html
2. My Exhaust Is Popping When I Am Slowing Down or Between Shifts
The version 12 software in your fuelpak greatly minimizes this popping. Your software version level can be checked in mode 20. Older versions can be upgraded for a nominal charge by contacting our technical service department.
The version 12 software is able to cut down on this popping by monitoring the throttle position in relation to the engine rpm; if the fuelpak was not calibrated to the throttle position correctly in mode 19, popping or other driveability issues can result. Check the throttle calibration in mode 21 – the numbers should read zero at idle and start increasing smoothly as the throttle is twisted, reading about 50 at half throttle and 99 at full throttle. If the numbers do not appear to be correct, recalibrate the throttle in mode 19.
Some riders do not completely roll off the throttle between shifts or when coasting to a stop. This riding style can lead to exhaust popping. Be sure to fully roll off the throttle.
Exhaust leaks can also cause popping. Check and tighten any leaking exhaust joints.
Lastly, some exhaust systems will pop and there is nothing you can do to completely eliminate it. Systems with large baffles or with open or non-existing baffles are especially prone to popping.
"To eliminate exhaust popping on deceleration, the Fuelpak will turn off the fuel going into the cylinders. If this feeling is undesirable, you can raise the number in mode 23."
