Motor mounts?
Old May 11, 2009 | 11:09 PM
Deadbroke_bootleg's Avatar
Deadbroke_bootleg
Default Motor mounts?
Whos bright idea was it to put the front motor mount under the oil filter?
Old May 11, 2009 | 11:10 PM
benwiggin2's Avatar
benwiggin2
what's the problem?
Old May 11, 2009 | 11:19 PM
Deadbroke_bootleg
Just that it seems that the motor mount is wore out already. Its an 07 street Bob. I figure with all the oil changes it seems to shorten the lifespan of the isolater. Maybe just a NooB brain fart.
Old May 11, 2009 | 11:24 PM
archergodwin's Avatar
archergodwin
Nope, analysis is right on.
Old May 11, 2009 | 11:25 PM
Deadbroke_bootleg
Looks like i can slide a jack under the motor and change em out. But the back one may be a bit harder. Or should i just take her in?
Old May 11, 2009 | 11:31 PM
Deadbroke_bootleg
I mean i think i can do this including the service maintenance stuff, but affraid i will mess us my warranty.
Old May 11, 2009 | 11:39 PM
archergodwin
If the mounts are bad, and the dealer agrees (always a crapshoot) I'd let them eat a slice of warranty pie.
Otherwise, if you're comfortable with it, go for it.
Old May 11, 2009 | 11:57 PM
benwiggin2's Avatar
benwiggin2
the one in back should be good for at least 10,000 mi (I think)
Old May 12, 2009 | 12:04 AM
OhioSkully's Avatar
OhioSkully
10,000 **** i hope more than that cause iam pushing 30,000 almost and haven't replaced either of them. and the bikes not 2yrs old. I had them look them both over last year and they said ok. Iam beginning to wonder though as i think theres more vibration now then before all the miles iam going to have them check them out this month when i take it in for cpl items i need taken care of on warranty before it expires i got the extended but then its $50 bucks a pop.
But you are right oil and rubber don't mix i try to lay rags over the mount when i take the filter off to keep some of it off the rubber but doesn't always work and sometimes it get oil all over it.
Old May 12, 2009 | 12:12 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
All you have to do is clean the oil off with some brakekleen or simple green and rinse well with warm water. It's just a piece of rubber. Now the guys who are total slobs and don't clean their bike...well they can replace the isolators all the time......... j/k
