Redline Heavy 75/90 Substitute?
Old May 13, 2009 | 05:25 PM
moosh's Avatar
moosh
mobil1 engine--ATF primary--redline shock proof tranny
would not use anything heavier than 20w in primary
Old May 13, 2009 | 05:31 PM
PigInaBlanket's Avatar
PigInaBlanket
This is what I use...
Mobil1 20W50 V-Twin synth in engine and primary
Amsoil 75W90 Severe gear synth in tranny.
I also use HD spark plugs, genuine earth air in my tires, Meguire's car wash soap, S-100 cleaner and wax, Pig Spit and last but not least I use Charmin after a late night Taco Bell run along with a huge Wal-Mart plunger as needed.
Old May 13, 2009 | 05:53 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Originally Posted by r00k
Lucas 75w90
Works amazingly well.
Just changed to: Lucas 85w140
Old May 13, 2009 | 06:16 PM
Dyna-Asa's Avatar
Dyna-Asa
why would you use gear oil in a primary? I understand ATF and engine oil, but gear oil makes no sense to me
Old May 13, 2009 | 07:00 PM
Robottom's Avatar
Robottom
Here's three things that convinced me to give it a try. I started off looking for Redline MTL for the primary, and Redline SPH for the tranny but cannot find them here in CA. (Original post question is what caught my eye on this thread.)
#1. After spending way too much time on the Internet, figured that the MTL product was pretty much gear oil as you can see from their spec.
#2. Understand that many folks use lighter oils, but based on finding many gear oils spec'd for primary (ex: KH-C80).
#3. After reading the HD Knowledge on Primary Oils, post #124, it would appear that they're pretty much the same. https://www.hdforums.com/forum/4594627-post124.html
I'm hoping this is not a hugh mistake, because I'm stopping on the way home from work this evening and getting the filter, o-rings etc. I've already bought the oils.... I guess I can always change it out later if it's sticky or hard to shift.
File Type: zip
Old May 13, 2009 | 07:08 PM
glideridemike's Avatar
glideridemike
Originally Posted by JRK5892
i used mobile 1 75/90 prior to readline shock proof... i think that the mobile was 1000000x's smoother!
I'm trying to find some Mobil 1 V Twin for my primary and tranny but so far all I've been able to find is the motor oil.
Old May 13, 2009 | 07:41 PM
PigInaBlanket
There is only one Mobil 1 V-Twin, it says it is safe to use in all 3 holes. I've never used it in the tranny on the Street Bob but I do use it in the engine and primary. I also used it in the engine and combined primary/tranny on the Sportster I used to have. It worked fine but just don't go looking for any Mobil 1 V-Twin branded tranny or primary fluid cause there ain't none.
jasonleahey
Jul 13, 2013 01:26 PM
The Cheesehead
Oil Archive (no new posts)
13
Apr 6, 2012 12:41 PM
steamer454
Aug 2, 2010 07:38 PM
ChromeJunkie
May 18, 2010 07:45 AM
thumper05
Aug 20, 2007 09:19 PM
