Lowering FXDF Fat bob
I know this topic has been discussed previously....but I need some definitive answers for my specific bike. I have an 08 Fat Bob, I am 5"6 and 160lbs. rarely if ever ride two up.
I need to lower my bike so that I can get a little more footing....that being said I have a few questions;
1- Do I have to lower the rear and the front...or is it safe to do just the rear. I get conflicting opinions locally from the dealers and bike shops.
2- I am debating between a rear lowering kit or the Progressive 412s full cover chrome. As they are a good price range.
My main concerns are bottoming out and/or the bike handling differently.
Cheers,
Mickey
I've lowered mine to where the belt guard was hitting the frame, the fender was hitting the belt guard and the master cylinder was hitting the fender.
I've since raised it enough to where these are not an issue any longer and the bike handles amazingly with the lower center of gravity.
I'm using 1.75" lowering blocks which I got off EBay for $40. I fine tune them with .25" thick pieces of rubber (the ones from under the stock seat) under the legs where the blocks rest on the swing arm. The spring pre-load is set on #2.
I slid the forks up the trees @ 1-1.25" for $0.
I highly recommend doing this. Not so much for preserving 'rake & trail' but mostly because it cost nothing to try for the day and is easily reversible.
It made a noticeable difference in handling, looked good and was more maneuverable in the parking lot.
As to scrapping the pegs & the pipes…
I have read that a very effective corrective action can be taken while you’re riding, while you’re in the turn, while you’re scrapping the peg.
When you begin to scrap… shift you body TOWARDS the side that’s scrapping. This causes the bike to move back towards vertical, effectively raising the peg off the pavement.
It sounds counter intuitive but it works.
As to the jiffy stand…
I removed mine, removed some of the material from the top of the lock tab with a grinder & reinstalled it… for $0.
http://www.youtube.com/watch?v=ijO67DFOJfY
hi I am 5'5 160lb. Would I be able to flat foot this bike if I do this?
I was at the dealdership today and I could not stand flat foot on the bike.
Also, I could not reach the shifter in the front and the rear breaks I am a bit short.
I know it's embrassing but I would like to know what my options are. I really want a fat bob.
BTW I was able to flat foot on the Fat boy lo but what I want is a Fat Bob
thanks!!!
thanks!!!
Looking at the specs for the seat height on the Lo at: http://www.harley-davidson.com/en_US...l/flstfb/specs
it says the seat height 'laden' (with a 180 lb rider) is 24.25"... 'unladen' it's 26.35", a difference of 2.1".
Looking at the specs for the seat height on the Fat Bob at: http://www.harley-davidson.com/en_US...del/fxdf/specs
it says the seat height 'laden' (with a 180 lb rider) is 26.1"...... 'unladen' it's 27", a difference of .9"... thats a stiffer ride, 1.2" higher!
For what its worth the seat height on my lowered Fat Bob (with an 09 Street Bob solo seat), 'unladen' is 25.5"... That's 1.5" lower than stock.
I'm not for certain how far 180 lbs compresses the shocks, but using the above specs comparatively I'd say the seat height on my lowered Fat Bob 'laden' would be 24.6",
a difference of .35" higher than a Fat Boy low with the same 180 lb rider.
I imagine that if I were to side the front forks up the trees another .35" I'd have dam near the same 'laden' seat height as a FB Lo.
The $1000 shocks mentioned in db252's post is almost the price difference between the two bikes.
http://cgi.ebay.com/ebaymotors/Harle...item1e5e33eb4f
wmo777
TIA
Dan
Lowering the front end only usually sharpens steering response but also may cause some 'twitchiness' in high speed stability. Conversely, raising the front end will increase high speed stability but with slightly slower steering response.
Whichever way you go, make changes in small increments until you achieve your desired results.
