Will Rinehart for Softail fit?
Old May 25, 2009 | 06:26 PM
YellowHawk's Avatar
YellowHawk
Default Will Rinehart for Softail fit?
I have a friend at work that has a set of Rinehart exhause on his 08 Night Train. Just wondering if they would work on my 06 Super Glide. I would assume not, but they don't look much different.
Old May 25, 2009 | 07:02 PM
YellowHawk's Avatar
YellowHawk
Nobody knows?
Old May 25, 2009 | 07:04 PM
Davii's Avatar
Davii
Not a clue. I wouldn't think so though. Try checking their website and see if the part #'s are the same.
Old May 25, 2009 | 07:05 PM
ackman1968's Avatar
ackman1968
As long as the clear the oil fill hole the rest can be made to work. The mounting bracket that supports the rear will most likely be different but you can make one or buy the right one from Rinehart.
Old May 25, 2009 | 07:06 PM
maddghost's Avatar
maddghost
I'm waiting for tomorrow to call bub enterprises for my self,they were closed today
you can call them too! 1 800 934 9739
Old May 25, 2009 | 08:05 PM
YellowHawk's Avatar
YellowHawk
Thanks for the help. He said he would sell them to me if they would fit. Now I just have to make sure they fit.
Old May 25, 2009 | 11:31 PM
ackman1968's Avatar
ackman1968
They will tell you they won't fit (personal opinion). You will most likely get an operator/order taker that will see they have different part numbers and call it at that. That said it doesn't mean they won't fit with a little work. The pipes on my bike are for a 2005 and older Dyna. There is a difference in the hardware for installation but the pipes themselves bolted up no problem. If you are good at making things work/fit you may be onto a set of pipes, if you're not one to make things fit where they don't belong I would say pass on them.
Old May 26, 2009 | 01:58 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
With ours being rubber-mounted "A" engines and the Softies rigid "B" engines, it's prob'ly set up to have a frame-mount for supporting the rear. Ours are entirely engine/tranny supported with no frame coupling. If the rear clamp/mount is not a "fixed" style and can be slid up or down the pipe instead, then it could be just a matter of clamping on a Dyna mount that will attach to the tranny, or fabbing one. If the clamp/mount system is unique for the Softie frame, it may be doable, but cost/time/fab prohibitive. Not speaking from any personal experience, but that's how I'd approach the challenge.
jktbnelson
General Topics/Tech Tips
Sep 6, 2017 09:47 PM
sporsterking1
Exhaust System Topics
Dec 6, 2016 11:20 AM
dimefan
Jul 21, 2012 09:29 PM
INTHERED
Apr 9, 2009 06:10 PM
murf1
May 3, 2008 04:40 PM
