Soak the Nuts First and Loosen a Little, reverse and repeat until there off.. 1/2" semi deep flex Socket and 1/4" drive works best for us.. When Installing the new pipes DO NOT Over tighten the Flange nut's you'll crush the Gaskets .. Use the Standard HD Gaskets ..( Screaming Eagle Gaskets Suck ) Get them ( Flange Nut's ) Good and Snug, Then a quarter turn.. Run it a day and re check ..
All good advice. I have changed my pipes twice, plus have had the sideshots on and off a few times. I also use the standard hd gaskets and no loctite. Never had any trouble. Not sure how your pipes mount, but withe sideshots its important to make sure the flanges are seated good at the heads before tightening any other brackets. To me that sounds like good advice for any pipe install.
Well, all was good advice.. but, I think you should HURRY UP and put them on and get a sound clip. I'm very curious to see how they look/sound!! HURRRRRRRRY.
Must not have happened, 'casue there aint no pics!
I don't have anything to add to the excellent advice above, so I'll just wish you good luck with the install, and hope you don't get a ticket for loud exhaust!
