Bub's are here!
Old Jun 4, 2009 | 07:11 PM
maddghost's Avatar
maddghost
Default Bub's are here!
Hey buddies I have my new exhaust ,it got here today, Bub7 2/1 I am going to get new gaskets from the dealer and a set of plugs while I'm at it , so The million dollar question , anything special I should watch out for? Looks like
I'm going to do this by myself. I have sockets and wrenches and a torque wrench and blue loctite , and a new fuel map from Jamie,and a computer....anything come to mind?
I can get beer and all kinds of whatever else I need so c'mon how hard will this be? or should I get someone to help me??
Old Jun 4, 2009 | 07:13 PM
Failz's Avatar
Failz
Since it's such a high heat application use the high heat sleeve retainer thread lock. Tube looks just like the blue except it's a gel for high heat.
Old Jun 4, 2009 | 07:14 PM
Failz's Avatar
Failz
It's an easy job, you should be able to do it yourself.
Old Jun 4, 2009 | 07:21 PM
maddghost's Avatar
maddghost
So far there only saying I need regular blue locktite for the bracket mounts. I bought some high heat stuff and was down because I have no need for it! LMAO
Old Jun 4, 2009 | 07:32 PM
Failz's Avatar
Failz
I was talking about where the exhaust mounts to the cylinder. Or wait, are they slip-ons?
Old Jun 4, 2009 | 07:39 PM
maddghost's Avatar
maddghost
No No full heders going on,they haven't mentioned loctite in that area yet,but I have it if I need it
Old Jun 4, 2009 | 08:02 PM
WingNut55's Avatar
WingNut55
Never LocTite the flange nut's ... Never
Old Jun 4, 2009 | 08:25 PM
maddghost's Avatar
maddghost
Thank you for that WingNut! Will they be hard to remove? They have been on , stock , for about 11000 miles. If I try with my socket set any danger of breaking them off? Or twisting the threads?
Old Jun 4, 2009 | 08:50 PM
WingNut55's Avatar
WingNut55
Soak the Nuts First and Loosen a Little, reverse and repeat until there off.. 1/2" semi deep flex Socket and 1/4" drive works best for us.. When Installing the new pipes DO NOT Over tighten the Flange nut's you'll crush the Gaskets .. Use the Standard HD Gaskets ..( Screaming Eagle Gaskets Suck ) Get them ( Flange Nut's ) Good and Snug, Then a quarter turn.. Run it a day and re check ..
Old Jun 4, 2009 | 08:54 PM
maddghost's Avatar
maddghost
WD 40 or the like I imagine,Wow big thanks for your time and consideration man! I'll need to get snap ring pliers tomorrow so I'll get whatever is good these days.
