Rough shift when smokin hot
Old Jun 12, 2009 | 11:41 AM
shotdwg's Avatar
shotdwg
Stage II
Default Rough shift when smokin hot
03 FXDWG - during the heat of the day (Tucson) have a helluva time shifting gears or getting into neutral when the block gets real hot. just changed out primary case lube and tranny oil is clean and proper level. any ideas? running non-syn oil, will that help? only a real problem when the bike is cookin
Old Jun 12, 2009 | 03:47 PM
kk6pg's Avatar
kk6pg
Redline Shockproof in the trans.
That or Amsoil will fix you up
Old Jun 12, 2009 | 04:40 PM
fixxr's Avatar
fixxr
+1 on the amsoil it helped me.
Old Jun 12, 2009 | 05:07 PM
dynarule's Avatar
dynarule
If you dont want to spend $15 to $20 on one qt of oil, you could just get the Lucas 85w140 gear oil (dino) for $6. Works as good as the high priced stuff.
Old Jun 12, 2009 | 06:21 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Check your clutch adjustment, adjust when the bike is at ambient temp. and adjust the push rod (adjustment screw) 1/2 turn out from lightly seated. Clutch adjustments on warm engines really messup the clutch when it gets hot. I useSyn 3 in the primary just for the little heat protection it gives, used it for 32k miles and no problems. But then again I don't have the heat here, but didn't have any problems in Sturgis or Biketoberfest traffic in Daytona.
Old Jun 12, 2009 | 09:29 PM
ELECTRICMONKEY's Avatar
ELECTRICMONKEY
Amsoil does seem to help.
Old Jun 12, 2009 | 09:37 PM
archergodwin's Avatar
archergodwin
I'm running B&M Trickshift in the primary right now. Have been running Redline HD shockproof in the tranny. Everything is feeling pretty good.... even hot.
Old Jun 13, 2009 | 12:03 PM
shotdwg's Avatar
shotdwg
Stage II
THANKS TO ALL! Give it a Shot
Old Jun 13, 2009 | 12:49 PM
rounder's Avatar
rounder
amsoil in tranny . trickshift or amsoil in primary. Cleared that problem right up for me. In Florida so I know what your saying.
Old Jun 13, 2009 | 09:22 PM
Splatter's Avatar
Splatter
You might try taking a couple of ounces of oil out. Maybe the heat is making the level get a little high which could cause difficult shifting.
