HCC Cycles (ebay)
Old Jun 23, 2009 | 09:39 PM
super05's Avatar
super05
Originally Posted by SC-Longhair
....... These new ones have a gradual transition from 1.25" - 1". I didn't like it. I called and wanted to exchange them. Chris explained the transition would be hidden when controls were installed. He was half right. On the brake side, yes the transition is hidden but not on the clutch side.....
The problem is that they need to cover all bases with one set of bars. The square transition works with your late model master cylinder, but will cause interference with older master cylinders and most non HD controls, so a taper or flat spot is required. The clutch side is tapered to accept hydraulic clutches, which would have the same clearance issues on that side. You have found the down side - without a hydraulic clutch, the controls do not hide the taper on that side.
Old Jun 23, 2009 | 09:40 PM
SC-Longhair's Avatar
SC-Longhair
Originally Posted by TIDE
Hey Vic, Just in time for the ride!!!
Yeah. I started the swap tonight about 10 minutes after I got back from picking it up around the corner. Some say that's 9min and 59 seconds too long.
I was gettin tore up by the skeeters so I'll do more tomorrow. Maybe get it done. Who knows. I have plans to ride down to Augusta,GA saturday. Hopefully I won't be in my truck for that ride.
Old Jun 23, 2009 | 09:45 PM
SC-Longhair
I don't disagree with you. The gradual transition is growing on me. I don't know.
esteboatan
May 30, 2017 10:23 AM
thoner7
Aug 16, 2012 08:03 PM
cjlandry
Jun 13, 2011 07:03 AM
Critter174
Jan 26, 2008 06:59 AM
PoorBoy
Dec 17, 2007 05:43 PM
