Which gear?
Old Jun 30, 2009 | 12:47 PM
  #41
Shag67's Avatar
Shag67
Originally Posted by txtec
did you have to change the belt with the pulley change??
I haven't put the pulley on yet but their website says :
"Installing a transmission pulley with more or less teeth than stock requires adjusting the rear axle forward (for more teeth on sprocket) or
backwards (for less teeth on sprocket).
Rear axle position adjustment for each one tooth change on transmission sprocket = + / - .125 inches (3.2mm).
Rear axle position adjustment for each one tooth change in belt length = + / - .280 inches (7.1 mm).
If there is not enough axle adjustment at the rear frame, it may be necessary to use a belt with more or less teeth than the stock belt."
Source:
http://www.andrewsproducts.com/PDF_f...08-catalog.pdf
Search on "6 speed" in that document and you'll find the above information and more. I exchanged email with one of the Andrew's guys and he echoed what the above information said. Since I'm going from 32 to 30 teeth on the transmission pulley I will need to adjust my rear axle back about 1/4". I checked on my bike and I have over 1/2" of adjustment left easily so I can use my stock belt.
Old Jun 30, 2009 | 12:51 PM
  #42
Shag67's Avatar
Shag67
Originally Posted by pelliott6
just put a tach on mine and been having a blast keeping it around 3K ;
my power band seems to be 3.5-4.5K and my shift light is set to 4.5.
I highly recommend a tach.
How difficult or easy was it to install the tach? Can you post a couple of pictures of it? What brand/model number? I'd love to install a tach on my Street Bob if I could make it look good. Thanks.
Old Jul 1, 2009 | 12:25 PM
  #43
pelliott6's Avatar
pelliott6
https://www.hdforums.com/forum/dyna-...thers-day.html
Granpita
Jul 19, 2013 02:11 AM
NYdyna
May 2, 2012 11:40 AM
Dancemax
Aug 12, 2007 01:57 PM
MAX EVO
Jan 17, 2007 01:16 PM
gilmour68
Oct 24, 2006 08:30 PM
