Do you use same oil in Engine, tranny, and primary?
I was told that you can use the same oil in the engine, tranny and primary??? Is this true? I know it doesn't sound right but a harley guy told me this. I know its a dumb question but I have to ask.......
The basic answer is 'yes'. That will "work" in all three holes.
Is it the best for all three holes, each with different lubrication needs? No.
The engine has high heat and bearing loads, the tranny has high surface loads, and the primary has a chain but also the wet clutch.
I've tried HD's Syn3 in all three holes, and it sucks! Sounds like I have marbles in the engine.
Just because it has been posted to death and up and again, just suffice it to say choose a good name brand oil, for the specific mechanical application.
Added:
Just for ***** and giggles: I currently use Mobile-1 Vtwin 20/50 in the engine, Redline heavy duty shockproof in the tranny, and B&M Trickshift in the primary.
I'm running Lucas synthetic 20/50 in the motor and primary. Lucas synthetic 75/90 in the tranny. It just seems to shift more smooth with the heavier oil.
