front fork cap install
Old Jul 8, 2009 | 01:45 PM
davenportm's Avatar
davenportm
Default front fork cap install
Hi gents,
Got a question that I hope someone can help me with. I tried putting back on the front fork cap but couldn't seem to get it to thread considering the spring is providing a lot of pressure. Does anyone know of a tool I can use or at least a work-around? I do have the bike raised but putting back on those caps has been a real pain in the *%!.
Old Jul 8, 2009 | 01:51 PM
bberck's Avatar
bberck
I used a socket that fit it to allow more pressure when screwing mine back on.
Old Jul 8, 2009 | 01:54 PM
JRK5892's Avatar
JRK5892
i put the tube back in the tree and push on it in there just get it started and then get a solid socket on it
Old Jul 8, 2009 | 02:04 PM
davenportm's Avatar
davenportm
Unhappy
I think I'll take the cap to the local auto store and get a socket. It has been quite a chore pushing that thing down to get it to thread. I thought I was pretty strong but it's making me feel quite inadequate at the moment.
Old Jul 8, 2009 | 02:05 PM
bberck's Avatar
bberck
I couldnt get mine started by hand either and it went on with the socket.
Old Jul 8, 2009 | 02:12 PM
Robottom's Avatar
Robottom
Definitely get the tube back into the trees, clamp higher than you would for actual mounting, just tight enough to hold the tube in place. Do whatever you need to do to be sure you don't pull your bike off your stand. And use a socket and an extension long enough to get your hand between the socket and ratchet. Then you'll have something to grip while you use the heel of your hand to apply downward pressure on the socket itself.
Old Jul 8, 2009 | 03:17 PM
Ratbob's Avatar
Ratbob
Default fork socket from EBAY
I got one of these off ebay - 17 bucks with free shipping.
Old Jul 8, 2009 | 04:34 PM
99superglide's Avatar
99superglide
You could use a regular socket, just put some nuts inside it to shim it down and make it shallower so you can apply pressure to the fork cap as you screw it on.
Old Jul 8, 2009 | 04:38 PM
BigLowRider's Avatar
BigLowRider
I'm a big guy and couldn't get it threaded using a socket and ratchet - I found it too difficult to press down and rotate at the same time. I ditched the ratchet and used a nut driver instead.
BigLow
Old Jul 8, 2009 | 05:32 PM
OldMike's Avatar
OldMike
I used a socket with a long extension for a handle and even then my mom had a rough timg getting it started, tube was mounted in the tree.
Mike
