another 30T power pulley install...
Old Jul 1, 2010 | 08:40 AM
  #121
GONZO6's Avatar
GONZO6
Originally Posted by drspencer
Will this mod show actual torque increase numbers on a Dyno machine, or just a seat-of-your-pants improvement?
Thanks
The mod will lower the final drive ratio, show slightly lower dyno numbers,
and give the "seat dyno" a very noticeable boost.
Old Jul 1, 2010 | 10:44 AM
  #122
spaceblue's Avatar
spaceblue
Thanks
The only thing that would change your torque numbers would be a modification that changes the amount being produced by the motor. This mod is after that fact and essentially is changing your final drive ratio which in turn allows the individual gear ratios of your transmission to be more user friendly in the real non-EPA world.
Old Oct 29, 2010 | 12:21 PM
  #123
rhinoWErX's Avatar
rhinoWErX
Question Speedo calibrate...
Just finished the 30t pulley swap and heavy-duty clutch upgrade on an 08 Dyna - awesome mod! It's like a new bike.
What I'm looking to do now is calibrate the speedo. Has anybody successfully done this on an 08 or later model bike?
Seems the Dakota Digital SIM-1 module might work, but needs to be spliced into the stock harness?
Has anybody done this or have any other suggestions for a solution?
Thanks,
-Jack
Old Oct 29, 2010 | 01:58 PM
  #124
Redbeard's Avatar
Redbeard
What tuner are you using? The TTS Mastertune can correct speedo calibration, not sure of others.
Also, what clutch did you upgrade to?
Old Oct 29, 2010 | 02:25 PM
  #125
rhinoWErX's Avatar
rhinoWErX
No tuner - just a stage I ECU upgrade. Clutch upgrade is H-D SE.
Old Oct 29, 2010 | 03:19 PM
  #126
icebite1's Avatar
icebite1
The TMax/AT tuner will be able to adjust everything, just pricey. I have 4 of them i like it so well and and it tunes itself and lots of free maps to pick from. Oh ya, 3 of the 4 have the 30Tooth primary drive pulley installed.
Old Oct 29, 2010 | 03:31 PM
  #127
rhinoWErX's Avatar
rhinoWErX
I had a TMax w/AT on another (H-D) bike - didn't really work out for me - difficulties getting solid interface connection (with PC), not many tuners here in SoCal work with the TMax (the zippers maps didn't work well).
Replaced it with a PCV and a custom Dyno map - much better set up.
Like I said, this bike only has the stage 1 download - considering getting a PCV for it but not sure if it can calibrate speed. Having said that, I hope I have more (cheaper) options than a $900 tuner...
Old Oct 30, 2010 | 12:31 AM
  #128
JimmieJack's Avatar
JimmieJack
Default Speedo Fix
Werx,
I used the "Speedo Healer". It plugs in - no splicing. However, because of the different gearing ratio you will loose the 6th gear light.
Anyway, I just got a TTS Tuner (haven't installed it yet). I will not be needing the "module" anymore - $50 and I'll mail it to you. PM me if your interested.
Jimmie
Old Oct 30, 2010 | 09:44 AM
  #129
Wireguided's Avatar
Wireguided
TTS does re cal the vss i have done mine with it..
Old Jun 13, 2011 | 08:50 AM
  #130
Paul32730's Avatar
Paul32730
Default Question About 30T Pulley with SE 255 Cams
I read this post and another about the 30T pulley and installation, etc. I looked at most people's signatures and noticed that this mod is mostly done by Stage 1 people. I didn't see anyone who had swapped cams or had head work done. So, my question is this: My SE 255 cams shifted my power curve from stock lower improving torque. As a result I'm shifting sooner and am realizing the improvements the cam swap made in 6th gear.
Will the addition of the 30T pulley increase the low end more than I'm looking for? I don't want to end up shifting my power band so low that my highway riding suffer as I do ride a couple of 2500 mile trip a years.
Thanks for the input in this thread and thank for any help/advice.
Paul
