another 30T power pulley install...
Old Dec 12, 2009 | 06:32 AM
  #111
Shag67's Avatar
Shag67
I haven't used one on my Harley but I used a similar product (speedo healer) on my last bike, a '06 GSX-R 750. Worked great after I swapped out the front and rear sprockets on the bike. Had a neat feature that recorded the top speed you'd gone on your bike, too. Of course you could erase that in case it recorded a slightly larger-than-legal number. I'd search ebay before actually placing an order.
Old Jan 31, 2010 | 06:39 PM
  #112
toyking23's Avatar
toyking23
I am doing the 30T change on a 07 Ultra Classic. The manual says to remove the bearing inner race using a puller. Is this required to remove the mainshaft lock nut?
thanks
Old Feb 2, 2010 | 12:42 AM
  #113
JimmieJack's Avatar
JimmieJack
The quick anwer is - NO. The service manual can be a llittle tricky to follow. I did a couple of reads before beginning the actual job.
Old Feb 2, 2010 | 08:47 AM
  #114
toyking23's Avatar
toyking23
Thanks, it didn't look like it but it said to. I confuse to easily. :-)
Old Feb 22, 2010 | 03:32 PM
  #115
rhinoWErX's Avatar
rhinoWErX
Smile
Hey guys, getting ready to do the Andrews 30T counter sprocket change on my FXDF - any one care to let me use their 2.25 socket (required to remove the nut)?
Seems like a waste to buy for a one time use.
And for those of you that used the impact wrench to crack the nut, how did you hold the sprocket to torque it up again?
Cheers,
-Jack
Old Feb 22, 2010 | 03:41 PM
  #116
toyking23's Avatar
toyking23
I gave up on trying to take mine off and glad I did. Took it to the dealership, watched the tech try, then put on a heat from a hand torch, then destroyed his snap on air gun, then finally after using heat from a big tank torch and heating up, with another air gun was able to break free. One part of the job I am glad I didn't do. But he did mention some come off easy and othesr don't
Old Feb 22, 2010 | 05:52 PM
  #117
BlockHead96's Avatar
BlockHead96
Cheers,
-Jack
Check Harbor Freight for the socket. I know what ya mean, I had to get a large socket for one time use to remove a Yoke nut off my front diff on my diesel. Still sitting in the tool box 10 years later!
Old Feb 24, 2010 | 09:46 AM
  #118
OkieNiteTrain's Avatar
OkieNiteTrain
This mod is the greatest thing I have done to my 07 Night Train!! I used the Andrews 30t and put on a new belt. The old belt was streched and needed to be replaced. The stock belt will work if it is in good shape.
This thing runs like a different bike now. Thanks for the info on this mod. I got most of it from this forum.
Old Feb 24, 2010 | 10:21 AM
  #119
hddave2's Avatar
hddave2
where can i order pulley and gaskets for 2006 dyna.what are the part numbers
Old Jun 30, 2010 | 10:29 AM
  #120
drspencer's Avatar
drspencer
Will this mod show actual torque increase numbers on a Dyno machine, or just a seat-of-your-pants improvement?
Thanks
